1 Bottom 7.5 fuse keeps blowing and now fuel pump isn't working. Wed Jun 22, 2016 1:26 am
MikeisonTV
I think Mike is referring to the "bottom 7.5amp fuse" which is #6 (the missing one).MikeisonTV wrote:Bottom 7.5 fuse keeps blowing and now fuel pump isn't working. Are these too the same problem? As in, does the fuel pump need that fuse to power (spin)?
1989 K100RT VIN 0097367 (naked) 1996 K1100RS VIN 0451808 | Fuel: 95 Octane Engine Oil: Nulon Full Synthetic 15W50 Gear Box Oil: Nulon Synthetic 75W90 |
kennybob wrote:The radiator fan is likely locked up and the stall current is blowing fuse #6.
The proper way to test the pump is to isolate it first, away from the circuit that's causing the short. In any case the fuse would blow straight way again so you'd be none the wiser. Don't even think about trying that without a fuse.kennybob wrote:Just to quickly test if the pump is working and to avoid sparks in the tank, with the key off, you could put a jumper wire from the right-hand side of fuse 4 to the left side of fuse 6 to put power to the fuel pump.
This is a test, it is only a test. Do not try to operate in such a manner.
most often its the simple solution. Onya rick.MikeisonTV wrote:I meant to update sooner. RICK nails it again...tighten up the 4 pin connector under the tank...she fired right up.
The fuse seems to be ok nowHolister wrote:most often its the simple solution. Onya rick.MikeisonTV wrote:I meant to update sooner. RICK nails it again...tighten up the 4 pin connector under the tank...she fired right up.
So whats causing the fuse to blow?
That's exactly how I did it. I clean the pumps using the same DIY method used for cleaning the fuel injectors.duck wrote:To test the fuel pump you can jump 12V directly to it. The smaller diameter terminal on the pump is 12V+.
Probably a good idea to make a point of not creating sparks in the fuel tank when doing this. i.e. Connect leads to the fuel pump first, then your power supply outside of the tank.
K100-forum.com » Technical, repair and troubleshooting » Electrical » Bottom 7.5 fuse keeps blowing and now fuel pump isn't working.
Similar topics
