1Back to top Go down   Warning light doesn't go out. Empty Warning light doesn't go out. Thu Jun 02, 2016 10:10 am
Danish biker
Danish biker
This morning the warning light didn't go out, as it normally does after using both brakes (abs). What could be wrong?
Warning light doesn't go out. Image_zpszstjz6q4
2Back to top Go down   Warning light doesn't go out. Empty Re: Warning light doesn't go out. Thu Jun 02, 2016 10:24 am
That usually means the bulb is faulty or it maybe the brake switch on either front or back lever. It is not an ABS fault as that will flash that light and the ABS light in the speedo.
3Back to top Go down   Warning light doesn't go out. Empty Re: Warning light doesn't go out. Thu Jun 02, 2016 12:31 pm
Danish biker
Danish biker
Thanks. It was the rearlight bulp. I was as work and didn't have the manual. As soon as I came home I checked the manual and sure VERY simple. Well there is a first time for everything.
You have enemies? Good. That means you've stood up for something, sometime in your life.
-Sir Winston Churchill
4Back to top Go down   Warning light doesn't go out. Empty Re: Warning light doesn't go out. Thu Jun 02, 2016 5:35 pm
WoodyAUK75
WoodyAUK75
Don't worry, I was the same the first time I had that problem. I took it to a mechanic thinking I needed brake work and he said " Doesn't that just mean the tail light has blown?" $2.00 later I was right.
5Back to top Go down   Warning light doesn't go out. Empty Re: Warning light doesn't go out. Fri Jun 03, 2016 12:28 pm
Danish biker
Danish biker
WoodyAUK75 wrote:Don't worry, I was the same the first time I had that problem. I took it to a mechanic thinking I needed brake work and he said " Doesn't that just mean the tail light has blown?" $2.00 later I was right.
Ha, ha I was thinking no Oil, no water = engine ruined, or at least new ABS $$$$$$$
