Number of posts : 7955
Marvin M wrote:Just registered. Thanks for acceptance.
Not quite up to full bike status as I've only got an engine.
I would like to get it running before I fit it.
So my enquires to come will be mainly based on setting up a test bed first.
Looks like I have a problem already as I have an incompatible wiring loom plug. It won't fit into the computer unit that's for sure.
Welcome on board too.
Now when you say 'the computer unit' there are two and you may have one, that is if its an 8 valve engine....Both are needed. One is located under the seat [if you had a full bike and is about 6 inches square and one inch thick. Best use imperial since you might officially be non metric in a few weeks. This one is the Fuel Injection Control Unit or FICU. The second one is located under the headstock at the front of the tank and is the Ignition Control Unit [ICU].
Post up the engine numbers as that will give the week and year of manufacture as well as engine type. Plate is on the right hand side rear of the oil filler plug and down below it.
On second thoughts do that first as the 16 valve has a different system with only one computer.
To get it running on a bench you may need clocks as well but there are some on the forum who will know how to get around this.
So, do you have a 'rest of bike' to fit the engine to?
1971 Yamaha 125 YAS-1
