1 Crank cover material Wed Jun 08, 2016 3:46 am
jrocker3235
Is the K100 crank cover made of cast aluminum? Thanks.
Aluminium alloy can't be anaodisedjrocker3235 wrote:Anyone ever seen or tried to anodize these their crank or cam covers?
1989 K100RT VIN 0097367 (naked) 1996 K1100RS VIN 0451808 | Fuel: 95 Octane Engine Oil: Nulon Full Synthetic 15W50 Gear Box Oil: Nulon Synthetic 75W90 |
jrocker3235 wrote:Thanks Kennybob. We use alodine at work and I am really looking at anodizing for the aesthetic aspect over the protective.
"More"?.... I've not seen any. There is a reason. Cast aluminium alloy cannot be anodised. It's composition is very different to extruded aluminium and even uses a different numerical system to identify its composition. Anodising creates an oxidised coating over the surface of the aluminium. This has a cellular structure which is then sealed off in the final process preventing further oxidation. With the higher content of alloy metals such as magnesium and copper you find in cast aluminium, this cellular aluminium oxide coating cannot form properly.jrocker3235 wrote:..... There has to be a reason you dont see more people anodizing the cam and crank covers though.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Crank cover material
Similar topics
