1 oil pressure light - bit odd.... Fri May 14, 2010 12:39 pm
erizo
just done a camchain replacement on an 8 valve k100lt.
flled up the fluids (new oil, BMW filter and antifreeze mix) , hit the button, all going well and good.
turned it off, left it a while, turned it back on again, and now the oil light is doing something strange.
with the ignition on the light is barely glowing. start the engine and it glows a bit brighter. rev the engine and it goes brighter.
bit odd IMO because if it was low oil pressure it should be bright at first and stay bright if the pressure was low, or if the system was running a bit low (as in not 100%) on pressure it should start bright and get dimmer instead of the reverse.
i realise these bikes have their idiosyncracies, so i thought i´d ask in case it was a known fault.
cheers guys!
cheers guys!
