1Back to top Go down   k1100 COMFORT SEAT Empty k1100 COMFORT SEAT Sat May 01, 2010 7:54 pm
paulcrtny
hi all will a k1100 COMFORT SEAT fit my k100 rt 1986 without any modifacation if not can anybody tell me anywhere in the uk i might find a comfort seat that would fit many thanks from paul.
2Back to top Go down   k1100 COMFORT SEAT Empty Re: k1100 COMFORT SEAT Sun May 02, 2010 12:07 am
The only modification needed will be to trim the bottom of the seat or cut 1" of the tool tray under the seat.
This is minor modification and I choose the option to trim the seat on my 1986 K75.
You will have to get the proper hinges for the seat too. The original K100 don't work with the comfort seat. The bike frame is OK, you just have to replace the back hinge.
k1100 COMFORT SEAT Frog15k1100 COMFORT SEAT Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   k1100 COMFORT SEAT Empty Re: k1100 COMFORT SEAT Sun May 02, 2010 7:43 am
Alex_GER
Alex_GER
Have a look for the 100 LT Comfort seat. That should fit without any modification. It worked for me and my 100 RS...
Jod alles chlor, liebe Krüße,
euer KLotz
k1100 COMFORT SEAT E088Doenerschuss || Portfolio || MPI
http://www.students.uni-mainz.de/alotz/portfolio/
4Back to top Go down   k1100 COMFORT SEAT Empty Re: k1100 COMFORT SEAT Sun May 02, 2010 12:29 pm
My seat is a BMW comfort of a K1100lt and not a K100lt.
This seat will work on a K100 too with the small modification on the pan.
The cut of the 1" bulge doesn't affect the comfort. If you want to keep the seat original, you can instead cut 1" of the height of your tool tray.
You can find used tool trays on Ebay if you don't want to modify yours.
I just found that the K1100 doesn't have a tool tray and this is why the seat has the bulge.
Now you know that you have 2 options. K1100lt or K100lt
Here is some picture taken when I was fitting the K1100lt comfort seat.
k1100 COMFORT SEAT Dsc_1010
k1100 COMFORT SEAT Dsc_1011
5Back to top Go down   k1100 COMFORT SEAT Empty Re: k1100 COMFORT SEAT Sun May 02, 2010 1:16 pm
paulcrtny
thanks for all the info will try and get the Comfort seat and have a go at fitting. again many thanks.
paul
6Back to top Go down   k1100 COMFORT SEAT Empty Re: k1100 COMFORT SEAT Tue May 04, 2010 6:59 am
paulcrtny wrote:hi all will a k1100 COMFORT SEAT fit my k100 rt 1986 without any modifacation if not can anybody tell me anywhere in the uk i might find a comfort seat that would fit many thanks from paul.
Check this on Ebay
Or this one
7Back to top Go down   k1100 COMFORT SEAT Empty Re: k1100 COMFORT SEAT Sat May 08, 2010 8:27 pm
reg_K100RS
Hmm
good info that, I find the RS seat a bit on the tough side
on long rides
