1 Need help choosing fork tube diameter bracket (41.3 not available) Fri Jul 28, 2017 4:42 am
boostd4
Trying to get this cafe/streetfighter project moving along.
I'm pretty set on ordering some Woodcraft hinged clip-ons, but don't know what kind of rise to get. It would be neat to get a 3" rise, mount them real low on the fork tube, and move them when I want to be comfortable on longer trips.
However, I'm going to be putting an MT03 style headlight on the bike and it also has fork tube mounts. Once I have it mounted on the tubes I'll be able to tell what rise for the clip ons (based on what space is left available along the tubes).
My problem is the headlamp brackets come in 39-41mm or 42-43mm. Was wondering if anyone who has been through this has found that 41mm still works or not.
Trying to decide if I want to get a smaller diameter clamp and have to sand it out, or buy something a bit bigger (like 50mm) and use a rubber shim (like a coolant hose cut to fit under the clamp and take up the room.
Thanks for any advice/opinions
