1Back to top Go down   Hand brake  Empty Hand brake Thu Mar 17, 2016 7:26 pm
akarua01
akarua01
Hi again (shouldn't leave your bike sitting) now the front brake lever won't pump up pressure. I haven't pulled it apart yet. Do I just strip it down or is there a simpler fix?
2Back to top Go down   Hand brake  Empty Re: Hand brake Thu Mar 17, 2016 8:22 pm
If there is any fluid leaking out you probably need a kit to fix it but try bleeding the system first. I had air get into the system on the K100 once and never figured out how.
3Back to top Go down   Hand brake  Empty Re: Hand brake Thu Mar 17, 2016 9:22 pm
+1 that... but if its leaking around the base of the reservoir it'll just be the o-ring on the base. Cheap and easy to replace.
 Hand brake  Austra12    Fuel:  95 Octane
4Back to top Go down   Hand brake  Empty Re: Hand brake Thu Mar 17, 2016 10:23 pm
Cheap and easy, unless the PO never flushed the fluid like on my K100. The taper where the o-ring seats was corroded so it leaked even after a thorough clean up... replacement of the hydraulic portion and reservoir where my only options.
5Back to top Go down   Hand brake  Empty Re: Hand brake Fri Mar 18, 2016 8:50 am
I read somewhere that once they start to corrode they've had it... the corrosion will always return. Fortunately, when I pulled mine apart to replace the o-ring, it was in ok condition.
6Back to top Go down   Hand brake  Empty Re: Hand brake Fri Mar 18, 2016 9:11 am
about to do mine again twb
the refurb I did a few years ago seemed to seal ok ...but I have noticed that it is leaking from the same area that you mention
fortunately this time I have an dremel type tool that can resurface the inner seal area / core of the reservoir metal work
its the pitting around the seal area I see as the issue
ill give it a try at least and report my findings
meanwhile I'm onto a hopeful solution to the core of the master cylinder piston- bore that might be a good recommendation instead of throwing $200 aussie sheckles away to the dealers for a new master cylinder
hope you find a solution mate
7Back to top Go down   Hand brake  Empty Re: Hand brake Fri Mar 18, 2016 11:21 am
Chaz, mine was literally flaking into bits, even carefully sculping it into some kind of funnel didn't help, and I knew it was a long shot when I fitted back up and went to bleed the brakes. It's not gushing, mind, but does set a bead of brake fluid within a coupla hours. My solution was to ask Mark and Dana at Vallantine's, a Seattle workshop, whilst delivering parts to them the other morning, whether in their pile of scrap upstairs they had a spare unit laying about. They did, and as we have a friendly relationship, gave the crusty old piece of kit to me at no cost! Praise be! Thank you. The reservoir looks like new, the innards acceptable, but I'll chuck a seal/piston kit into it and we should be laughing. I too don't wish to part with too much dosh on this project, though she's coming up pretty clean after a few essentials and a bit of a scrub up. The K100 inches closer to the road, at last.
Wish I'd known in February that you needed a MC as I've got my clean, useable RS original in my shed in Beenleigh. Doh!
8Back to top Go down   Hand brake  Empty pumps bothways Tue Apr 05, 2016 7:24 pm
akarua01
akarua01
Hello again well I pulled the master cylinder apart and cleaned it and when I test it, It seams to pump and suck any ideas, it was not leaking so that's not a problem. Question
9Back to top Go down   Hand brake  Empty Re: Hand brake Wed Apr 06, 2016 12:04 am
Check that both holes from the resevoir to the cylinder are open, one is very obvious and the other is very small and can be overlooked easily. It is about 0.5mm in diameter and is just forward (away from the lever) of the larger hole.
10Back to top Go down   Hand brake  Empty hand brake Wed Apr 06, 2016 6:21 am
Gordon Smith
Gordon Smith
A touch of Phosphoric Acid usually stops the dreaded white worm in Aluminium.
11Back to top Go down   Hand brake  Empty hole Wed Apr 06, 2016 6:57 am
akarua01
akarua01
Thanks as soon as I get home I'll have a look for an extra hole I only noticed one the other is probably blocked I'll be home Tuesday
