Go to page : 1, 2  Next
1Back to top Go down   1984 K100RT Restoration Empty 1984 K100RT Restoration Tue Sep 18, 2012 8:00 am
tintock
tintock
Well, I've finally bit the bullet and decided to start on the restoration of my 1984 K100RT.
It's been lying up in my garage for 5 years without turning a wheel after it failed its MOT in 2007 with stiff steering and excessive fluctuation of front and rear braking effort. Daft, I know, but after the failure I sort of took the huff at the dealership, the bike and anything to do with biking!
Anyway, I'm back on track now and good to go. I'm not particularly skilled in matters mechanical - I can unbolt/unscrew stuff without too much effort but it's the oily bits that scare me! I'm hopeful that I can strip everything down to the frame without the necessity for delving into the bike's innards.
1984 K100RT Restoration Ap104012
It looks a bit tatty, I know, but I'm sure a good clean-up and a paint job on the frame and tank/fairing/sidepanels will do wonders. I'll probably have to get the seat re-upholstered too as it's worse than sitting on a rough plank and no-one seems to sell replacement seats for the 1984 bikes. I know I won't be able to manage the sort of restoration that other members (I'm following HALO's sterling efforts) have achieved, but I know my limitations!
I've got the tank off and drained the old fuel so I can put some fresh stuff in and see if the old girl will burst into life before I start taking her apart. Of course, it doesn't help that I've lost the original keys for the bike, but I've found a spare ignition key and I've managed to jiggle the fuel filler cap open with an old, worn ignition key. Don't know how I'm going to fix that problem as no-one seems to stock lock barrels and keys for the 1984 models.
The battery is goosed, of course, so I've ordered a Motobatt MBTX30U from eBay and a servicing kit from Motobins. Some years ago, Im sure I was their best customer for a while and I get the feeling that our relationship is going to become expensive again lol!
I'm also thinking of getting
this motorcycle lift from M&P to help with taking the engine off the frame. The reviews seem to be positive enough and I was wondering if anyone here has one.
I'm anticipating that this job will see me over the winter and I'm hopeful that the job will be done in time for next Spring.
Wish me luck!
Very Happy
2Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 8:04 am
Good luck! Very Happy Very Happy
BTW. A bit diffcult to judge from the picture, but it looks like you got the newer type of filler cap (from 04/85), so a lock barrel shouldn`t be any problem.
It was a recall on the early type filler caps.
3Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 8:19 am
Instead of droping the engine out it is easier if you look at it like you lift the bike of the engine.
Block the engine on the flat sump and then lift the rest of the bike away It is easier.
4Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 8:21 am
Rick G wrote:Instead of droping the engine out it is easier if you look at it like you lift the bike of the engine.
+1
5Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 8:41 am
tintock
tintock
Thanks for your comments, Inge K. and Rick G!
I've taken another couple of photos of the partially-stripped fuel filler cap.
1984 K100RT Restoration Ap104013
1984 K100RT Restoration Ap104014
The bike was produced in 10/84 and the filler cap was on the bike when I bought it, so I can't say if it was the original or was replaced by a previous owner. Motobins only seem to sell the lock and keys for K bikes 1986 on, so I still might be stuck.
And thanks for the info about lifting the frame from the engine - that's saved me £65 + shipping!
6Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 8:48 am
You can use the barrel from Motobins.
1984 K100RT Restoration 94615110
Early caps did have a push button.......and other barrels.
7Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 8:57 am
tintock
tintock
Inge K. wrote:You can use the barrel from Motobins...Early caps did have a push button.......and other barrels.
Excellent! Thanks again for your help!
8Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 9:03 pm
Halo
Halo
Tintock well done a fantastic candidate for a resto, hope your garage is warm for the winter resto. Take lots of photos during the strip down so you can see were bits went and if you can buy some cheap take away food containers and group the mounting hardware (bolts nuts etc) into the containers, no real need to mark them just group the bits that comes off a major part you are pulling down. I didn't at first and wish I did. All you need now is a $150 sand blasting cabinet & a decent commpressor, fine wire brushes with detergent I use lots of cheap degreaser cans as well now. Good luck 1984 K100RT Restoration 112350 .
Halo
84 K100RS 0014803
93 FZR1000 EXUP
9Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 18, 2012 11:18 pm
Tintock, good luck with your resto. A word of warning....beware of A SAFE PLACE. I pulled down my bike some time ago and put some bits and pieces in A SAFE PLACE. They are still there. One day I will rediscover this magical land and then having plenty of more spares.
10Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 4:12 am
tintock
tintock
Hi Halo and ainsjac. Thanks for your wise words and encouragement! Smile
Taking loads of photos and grouping the components of a major part is a great idea - I'll certainly be doing that. I'm also bagging and labelling the small parts - nuts, bolts and fasteners - in small ziploc bags because, if I don't, I know for sure I'll lose track. It takes a little bit longer but this isn't a rush job so time isn't really a factor.
And I will definitely find a safe place for the bits! I'm clearing out my loft at the moment, so there should be plenty room for bits that don't need immediate attention like the fairing, seat, panniers and top-box etc.
Many, many years ago (in what feels like a galaxy far away lol!) I once dismantled a CX500 for restoration and ended up selling it in boxes to a mate for £50! I'll try not to repeat that effort... Smile
11Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 5:34 am
This is what I did. Lots of bags. Lots of bits of paper inside the bags and felt pen on the outside as extra insurance.
I managed to get the bike back together with most of the bags empty.
Takes 1 minute to get a bag, piece of paper, what they are, little sketch if needed and the bits can't fall out.
Hmmm. Most of the bags empty.
I think I have found your safe place guys. Obviously they are not parts for my bike or they would be on it.
1984 K100RT Restoration Dsc_1215
rossco
12Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 6:01 am
rossco wrote:I think I have found your safe place guys. Obviously they are not parts for my bike or they would be on it.
rossco
Ah great, you found it....is my gearbox input seal there Rossco?
That bike looks like a great candidate for a resto Tintock. You've given yourself a realistic timscale too. We will follow your updates with interest, good luck with it.
88KE
1984 K100RT Restoration Ir-log1188....May contain nuts!1984 K100RT Restoration Ir-log11
K75RTP - 1994
13Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 6:16 am
tintock
tintock
Thanks for the encouragement, rossco and 88KE!
rossco, maybe you could have a wee look in the box for my original set of bike keys!
This is what I've started doing with the small parts...
1984 K100RT Restoration Ap104015
...and I'll be taking up HALO's suggestion about grouping major parts together.
Re the timescale, 88KE - my philosophy for this job is "Do a Little, Change a Lot". I just hope it works out! Smile
14Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 1:35 pm
tintock
tintock
Well, 2 days after they were ordered, the service kit from Motobins and the Motobatt MBTX30U battery from an eBay seller both arrived. Excellent service indeed!
1984 K100RT Restoration Ap104016
1984 K100RT Restoration Ap104017
The only problem was that the terminal adaptors that were supposed to be included with the battery weren't. So no chance of connecting the battery up tonight, but I've emailed the seller so, hopefully, the terminal adaptors will follow shortly.
15Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 5:30 pm
And so it begins !!!!!! fast work.
K75RTP - 1994
16Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 6:12 pm
Just another suggestion...worth considering. I came across so many rusty, broken and bent screws and bolts. I should have bitten the bullet earlier by buying boxes of new washers, bolts etc and replacing the crap ones with new ones straight away in the plastic bags. That way you have the correct number in the bags and you don't have problems later trying to reassemble with bent stuff, stopping , going to buy new ones and then doing the whole thing again a few days latter. If you are going to repaint the bolts etc....easier to paint new ones rather than stripping off paint,etc .
Stainless steel is worth considering.
17Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 6:24 pm
wow fast turnaround tintock
have fun !
18Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 6:33 pm
JR_K100RS
JR_K100RS
I'm with you Ainsjac , I've replaced nearly every screw , nut & bolt with stainless ones over the past 25 years , the caliper bolts get ratty very quickly from the brake dust , another tip is to polish the heads of the stainless bolts , it makes them even more resistant to corrosion , just put them in a cordless drill and give em a quick spin inside a rag with a bit of autosol , takes a few seconds per bolt , makes everything sparkle !
JR
Melbourne Australia
19Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 6:40 pm
Hi tintock,
As ainsjac and JR suggests, I would go for new stainless fixings from the start. All of my bikes have had ss nuts, bolts and screws for donkey's years and they never go rusty. But they must be lubricated on assembly.
Good luck with the re-build,
20Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Wed Sep 19, 2012 7:43 pm
What do you use to lube them Paul?
K75RTP - 1994
21Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 1:12 am
tintock
tintock
Loads of excellent suggestions there folks! I've considered replacing the existing fasteners with S/S parts, but I wasn't sure about the costs involved. It's certainly something I'd like to do, that's for sure. Lubing the fasteners is a definite - anything that makes this a one-time restoration appeals to me!
Clearly, many people have done this sort of thing before. Does anyone know if there any links that would help with the types, sizes and quantities of the different fasteners required for this job?
I like the idea that I can quickly tell what's needed by comparing the stuff I've bagged with new equivalents and the Autosol tip is one I'd never have thought up on my own.
Who Cares Who Wins
22Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 2:40 am
tintock
tintock
This is just really a personal reference list of major parts I have replaced since buying the bike in 2001. It's the first time I've quantified the costs and, frankly, I'm astonished that the total almost equals what I paid for the bike.
There's a wishlist at the end which will, no doubt, grow alarmingly as the restoration continues. Smile
2001: Total Cost = £289.47
External Exhaust Heatshield and associated parts
Shock Absorber
Choke Lever
Miscellaneous Bits'n'Bobs
2002: Total Cost = £53.46
Right Glovebox Lid, Fitting Kit and Lock
2003: Total Cost = £677.19
Progressive Suspension Fork Springs
Horn Kit
Fork Boot
Replacement HT Leads
Brake Bleed Nipple
S/S Front and Rear Brake Hoses
Rear Master Brake Cylinder
Front Master Brake Cyclinder Top Cap, Vale and Bellows
Read Brake Cylinder Reserve
Fairing Gaiter
Ignition Lock and Keys
K100 Microfiche
Front Brake Cylinder
Front Brake Switch
2004: Total Cost = £305.75
48 litre H&B Top Box, Rack and Backrest
Battery
2006: Total Cost = £11.70
2012: Total Cost = £186.94
Motobatt ABTX30U Battery
Tools
280-pce Stainless Allen Bolt Kit for K100LT
Cleaning Sundries
Miscellaneous Parts etc.
Wishlist
Fuel Filler Cap Lock and Keys
Steering Head Bearing x 2
Stainless Steel Fastener Kit (Under consideration)
R/H Fork Gaiter
Who Cares Who Wins
23Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 3:15 am
hmm 11 years and thats all you have spent on a bike 28 years old .....and mostly on upgrades ....cheeeep !!!
24Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 3:56 am
tintock
tintock
charlie99 wrote:hmm 11 years and thats all you have spent on a bike 28 years old .....and mostly on upgrades ....cheeeep !!!
Aye, well, that's only my personal expenditure - don't forget it's been off the road for over 5 years. It doesn't include the costs incurred by previous owners either - the nearly-complete service history for the bike tells it's own story.
Anyway, I'm expecting that this restoration will be anything other than cheap! One lesson I've learned from previous experience is to try as far as possible to obtain parts in a single order. Reviewing the shipping charges from previous purchases was an education! Shocked
Who Cares Who Wins
25Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 4:12 am
aye! freight can be a killer
in most cases anything to do with rubber will be "past it " unless replaced somewhere before now .
good luck with the resto
well be watching
26Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 5:36 am
tintock wrote:Clearly, many people have done this sort of thing before. Does anyone know if there any links that would help with the types, sizes and quantities of the different fasteners required for this job?
You can buy kits with all the screws included at Motobins/K series/accessories and at Motorworks.
27Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 6:22 am
tintock
tintock
Inge K. wrote:You can buy kits with all the screws included at Motobins/K series/accessories and at Motorworks.
Thanks for the info. I noticed that both these suppliers sold the kits but I had hoped to pay a bit less than their respective asking prices. I suppose I'm fitting the stereotypical image of a Scotsman here and, in reality, I've no idea what it would cost to source the parts individually, but I'm turning purple at the thought of parting with over £200 for a fastener kit.
It may, of course, come down to that - but, in the meantime, I think I'll need to go for a lie-down! Smile
Who Cares Who Wins
28Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 6:30 am
There are ebay options Tintock.
I had a look and could not find any at the moment found THIS and I am not sure how complete the kits are, but they tend to come from the UK.
And then looking I saw THIS one. 10 pound.
Do a google search. There are plenty of kits/ sets out there a lot cheaper than 200 pound
All I know about stainless is how shiny Halo manages to get it.
Plenty of bolt people here to help out.
Probably a couple of nutters too.
rossco
29Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 6:54 am
tintock
tintock
rossco wrote:There are ebay options Tintock...
OK! I'm back up off the floor now lol! Thanks for the links, rossco - and for the humour too! Smile
Who Cares Who Wins
30Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 3:53 pm
Hi tintock, have a look at these
http://www.ebay.co.uk/itm/280Qty-STAINLESS-ALLEN-BOLTS-KIT-BMW-K100-LT-/150629114147?pt=UK_Motorcycle_Parts&hash=item231231e123
Not a complete set but a good start. I bought some recently and they look pretty good quality.
88,I usually use Coppaslip.
31Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 4:59 pm
tintock
tintock
sidecar paul wrote:Hi tintock, have a look at these...
Thanks, Paul. I think that's much the same set of S/S bolts that rossco mentioned - they're about 57p cheaper buying direct rather from their eBay shop, but it's very useful to get your personal recommendation as someone who's bought the product. I think I'll buy them - definitely can't complain about the price, that's for sure! 1984 K100RT Restoration 112350
I may also go for the US fastener set rossco mentioned as it seems to be more comprehensive, but I'll see how I get on with these ones first. Thanks again! Smile
Who Cares Who Wins
32Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Thu Sep 20, 2012 6:33 pm
Halo
Halo
I love this thread I'm getting some good vibes on this one. The bolts yes when I saw the 200pound ask at motobins I choked the first time I ordered parts early this year. Doing up the old ones takes alot of time, proberly not as good as new ones but feels rewarding to me. SCP how can they sell the ones you found so cheap ?, would they send to Aussie ?.
I would like to see you get a sand blaster cabinet though tintock for those rusty parts it's just sooooo good.
Halo
84 K100RS 0014803
93 FZR1000 EXUP
33Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Fri Sep 21, 2012 4:01 am
tintock
tintock
Halo wrote:...I would like to see you get a sand blaster cabinet though tintock for those rusty parts it's just sooooo good...
Aye, Halo, I would love to sort myself with a sand blaster/soda blaster setup too, but I don't think I can justify the expenditure on a suitable air compressor and all the other associated bit'sn'bobs. Especially with Xmas coming up over the horizon. Even a week's hire of a suitable machine costs £200 locally.
Unless something turns up, it looks like it'll be brass wire brushes and elbow grease. I can't say I'm looking forward to that phase of the resto, but that's life I suppose!
BTW, I put a WA address into the BoltMeUp website with that pack in the basket and it just returned the same shipping costs as it cost me - i.e. £1.89. Somehow, I think they'd be looking for a bit more to ship to Oz but worth an email enquiry perhaps?
Who Cares Who Wins
34Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Fri Sep 21, 2012 4:48 am
I have bought a couple of these brushes over the years...as an option if you don't have a blaster.
http://www.machinerycleanery.com/
The brushes themselves are of good quality and last well.
Sean.
35Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Fri Sep 21, 2012 5:39 am
tintock
tintock
Saxon7 wrote:I have bought a couple of these brushes over the years...
Thanks for the link, Sean - these are worth bearing in mind for the fiddly bits if I get stuck. 1984 K100RT Restoration 112350
Who Cares Who Wins
36Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Sat Sep 22, 2012 9:48 am
Halo
Halo
The brass circular wire brush wheels inparticular I have had great success with you can put them on a drill
84 K100RS 0014803
93 FZR1000 EXUP
37Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Sat Sep 22, 2012 12:30 pm
tintock
tintock
Halo wrote:...brass circular wire brush wheels...
Aye, I took advantage of an offer in ALDI a few months ago and bought 3 packs of assorted power tool brass brushes and handbrushes. I've a feeling 3 packs won't be enough! Smile
Who Cares Who Wins
38Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Sat Sep 22, 2012 1:09 pm
tintock
tintock
I took advantage of some sunny weather today and got some more work done. Note that I didn't say "sunny and warm" - I had to scrape the ice off my windscreen this morning!
Anyway, with the tank, seat and lower L/H fairing panel off a couple of days ago, this is how it started off.
1984 K100RT Restoration Ap104018
1984 K100RT Restoration Ap104019
I have to admit that my heart sank a bit when I saw the extent of the corrosion, but then again, much of the bike looked as if it might be OK.
1984 K100RT Restoration Ap104020
1984 K100RT Restoration Ap104026
The underside of the seat is particularly extensively rusted, although it's probably just surface corrosion. I'll have to have it re-upholstered anyway as I don't think that either new or pattern seats are available for the 1984 RTs. The panniers will come up nicely and the Hepco & Becker topbox is virtually brand new (if a purchase made in 2004 can be referred to as "recent").
To be fair, many of the alloy and engine parts seem to be fine at first glance.The wheels and fork legs were powder-coated in 2003 so they should also be OK after a good clean-up.
1984 K100RT Restoration Ap104021
1984 K100RT Restoration Ap104022
This is how it finished for the day.
1984 K100RT Restoration Ap104023
1984 K100RT Restoration Ap104024
I was (temporarily) beaten by the 2 Allen bolts securing the tailpiece
bar which doubles up as a seat hinge, as the nuts at the bottom were
just spinning around with the bolts. I couldn't lay my hands on my
needle nose Mole grips, so I decided to retreat and have a a bottle of
home brew instead. The bolts can wait for another day!
1984 K100RT Restoration Ap104025
Cheers!
Who Cares Who Wins
39Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Sat Sep 22, 2012 8:57 pm
The nectar of gods and bottled by a saint it just has to be a good drop. 1984 K100RT Restoration 502531
40Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Sun Sep 23, 2012 4:50 pm
1984 K100RT Restoration Sam_0211
Bless you, my son,...hic drunken
41Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Sun Sep 23, 2012 7:31 pm
Toto_jp
Tintock to clean up the motor I'd use CT 12 its a mild sulphuric acid or its equivalent use a paint brush from the bottom up you will not get any streaking
cheers Tony
K100 RS 1986
42Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Mon Sep 24, 2012 3:26 am
tintock
tintock
Thanks, Tony. I'm not familiar with CT 12 over here in Scotland, in fact, I'm a bit out-of-date on the subject of engine/parts cleaners and degreasers. I'm one of the "Gunk" generation and I'm a bit clueless about what products are available nowadays.
I'm reading up on lots of the restoration threads - primarily those by HALO and OldGoat at the mo - to learn as many tricks and tips as I can before I get started for real. There seems to be loads of products and services in Canada, the US and Oz that I'm simply unaware of here - probably because I haven't really started looking in earnest yet.
I'll keep my eyes open for a mild sulphuric acid cleaner, though, as I'm heading out today to begin stocking up on cleaning stuff.
Who Cares Who Wins
43Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Mon Sep 24, 2012 1:50 pm
walfish
walfish
I'll keep my eyes open for a mild sulphuric acid cleaner, though, as I'm heading out today to begin stocking up on cleaning stuff.[/quote]
Something like Jeyes Fluid ??? - just don't get it on the paintwork.
1984 K100RT Restoration Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
44Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Mon Sep 24, 2012 3:25 pm
tintock
tintock
Interesting suggestion, ungaas.I've got Jeyes Fluid which I use in the garden for general disinfecting and cleaning, but it never occurred to me to use it on the bike! I looked up its specs on Wikipedia and see that one of the constituents is tar acid and, on the Jeyes website itself, it lists a pH value of between 8-10.
Your idea prompted me to find out a little more about the use of sulphuric acid solution in household cleaning and I found that B&Q sell a litre of drain cleaner called One Shot. I did a little more digging around the web and discovered that it's 91% sulphuric acid. I'm not sure I'd want to brush concentrated acid onto the bike, but of course, maybe someone out these already has.
In another life, I used to dilute fuming sulphuric acid (oleum) for lab use and it was scary stuff. I never forgot to add the acid to water instead of the other way around. It got bloody hot and lively enough doing it the proper way!
Who Cares Who Wins
45Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Mon Sep 24, 2012 7:18 pm
That's mighty progress Tintock! you'll be amazed how well some of those parts clean up. My engine cover bolts looked like yours and a quick lash in the brass brush followed by some 1200 or 1500 wet'n'dry had them back to mirror, I really couldn't believe the quality thats in some of these parts. You'll get there!
K75RTP - 1994
46Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Mon Sep 24, 2012 7:20 pm
Halo
Halo
This is good I would like to see you try this on the Al parts as I never did but was thinking I could have. Mybe this will be a way around the sandblasting and soapy water wire brushing I did on the Al parts.
84 K100RS 0014803
93 FZR1000 EXUP
47Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 25, 2012 4:28 am
tintock
tintock
88KE wrote:That's mighty progress Tintock!...
Aye, mate. It's amazing how much better progress appears to be once the fibreglass and seat comes off. Still a lot of work to be done, of course, but I'm looking forward to the job and getting the old girl properly ready for the road again.
I was up clearing out the loft the other day so I could make storage space for the fairing parts etc., and I came across a power tool I forgotten I had - a 160W dremel-type tool, complete with vice, stand, flexible drive extension and all the bits, plus a box of new wire brushes, cutters and grinders. An absolute bargain for me as I was contemplating splashing out £80 on a dremel for this restoration.
Halo wrote:This is good I would like to see you try this on the Al parts...
I'm tempted to try out the drain cleaner on the aluminium parts, but I think I'll do a bit of research and reading before I consider trying it. I'm concerned about damaging the soft metal parts with such a strong acid and I can't remember what effect dropping some water on 91% sulphuric acid would have. I could always dilute it, but it was over 35 years ago when I used to do the lab stuff and my memory is a bit hazy on the whole subject. And on everything else as a matter of fact lol! Smile
Who Cares Who Wins
48Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 25, 2012 5:20 am
Toto_jp
yep make sure you dilute it first don't use it neat (acid that is ) and start at the bottom going up stops streaking
I used this on my furniture trucks body kept it looking near new
cheers Tony
K100 RS 1986
49Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 25, 2012 5:23 am
tintock
tintock
Toto_jp wrote:yep make sure you dilute it first don't use it neat...
Thanks for the info and tips. It's all good! Smile
Who Cares Who Wins
50Back to top Go down   1984 K100RT Restoration Empty Re: 1984 K100RT Restoration Tue Sep 25, 2012 5:34 am
tintock
tintock
I know I'm getting a bit ahead of myself here, but I really fancy using the KBS ClearCoat that HALO put on his engine and metal components. There is a KBS agent in the UK, but they don't do the aerosol cans and I don't have any spraying equipment.
Is there a UK equivalent for the KBS ClearCoat or do I have do ask my daughter to bring a few cans with her when she comes over from WA for Xmas?
Who Cares Who Wins
