1Back to top Go down   get off abs from k1100 PLEASE HELP Empty get off abs from k1100 PLEASE HELP Fri Mar 25, 2016 6:43 pm
ranfart
ranfart
Hi everybody.
I need your help :/
I need to get off the abs from the k1100.
I supposes i can keep the ring on the disc brake (until i will not get floating disc) but I need to get off the abs.
I preferred to put another brake (like some brembo) and also I've get the rearset from speedwork with the rear pump and I would to use it.
Please could link/write a step by step how to to get off the 12 kg of abs Smile ?
Gabriele
2Back to top Go down   get off abs from k1100 PLEASE HELP Empty Re: get off abs from k1100 PLEASE HELP Fri Mar 25, 2016 10:03 pm
I can't give you a step by step, just general ideas.
The brake system needs a master cylinder, a wheel cylinder, and a hose to connect them.  That is all you need.
Remove everything else.
You will need new hoses.  I can't tell you what hoses to get because you want to use rear set pegs and different calipers.
I would mount all the parts and then measure for the hose.
Hope this helps,
