1Back to top Go down   WARNING on non OEM reservoir hose. Empty WARNING on non OEM reservoir hose. Fri Oct 04, 2019 12:31 am
BE WARNED. I  was investigating a weep coming from just below the adaptor that went between the OEM reservoir hose and the Chinese hose. As I tried to wipe where the leak was occurring the hose just split and dumped the contents of the reservoir on the garage floor. I went to my favorite local brake guy to go and get a new hose and some brake fluid. He had a look at the split hose and said it was definitely not rated for brake fluid and said it was dangerous in this application. He shook his head when I said it had been supplied with the master cylinder.
Has this just happened  ?
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
Yep I was just giving the Brick I final check. I saw a weep that appeared near the reducer I gave it a wipe and the hose just split and dumped the fluid. It split just under the hose clip, and I didn't even really wipe it hard. The new replacement is marked as brake hose. I count myself lucky it probably would have split on the way to the Toad and dumped fluid over my back tyre.
WARNING on non OEM reservoir hose. Reserv10
WARNING on non OEM reservoir hose. Reserv11
volador
volador
Should rename "WARNING CHICOM CHIT HOSE Use At Your Own Risk"
Have a good Toad
