1 Relay Identification Fri Jan 22, 2016 2:36 am
Big G
Hi guys
Still on the trail of intermittent cut-out at high temperatures.
I must still do a proper test on the Hall sensors, but could not replicate the cut-out problem using a hairdryer - will warm them properly over the weekend when I get hold of a heat gun .
However, I think the relays are overheating. In my previous posts I mentioned that I was reading temperatures of around 50 deg C, and in the last instance, when I experienced the last cut-out, it went up to 62 deg C.
I have now fitted a 60 mm x 60 mm 12 V panel fan to the rear of the relay box, inside, under the start relay. The idea is to draw fresh air from under the seat (hopefully it will stay fresh ) providing forced ventilation to the relay box (the cover does not fit tightly, so the air will be pushed out there).
I now have to provide power to the fan, and want to connect it to the main cooling fan circuit (no use in having my relay box cooling fan running unneccesarily) - I am also considering a "tell-tale" light on the dash (I saw a similar post here somewhere on that as well).
I want to take 12 V from the switched side of the main cooling fan (so that when it switches on, my relay box fan also gets power), via a small fuse for protection, which I will add to the existing fuse rail.
Now - I have seen posts on this forum showing the fan motor is switched via the "Temperature Sensing Switch Unit", which is also as shown on the Interactive wiring diagram. This is also as per the wiring diagram in my Haynes service manual. According to all these diagrams, I will get my 12 V from pin A2 on the relay.
HOWEVER, my wiring is different (K100 RS 4-valve 1990), and the closest description I could find of my particular relay box layout was on the Motobrick forum:
Below is a picture of my actual box:
Relay ID's (according to Motobrick's pic):
1: Motronic (? - not sure what this is)
2: Fan
3: Horn
4: Fuel pump
5: Load shed
6: ABS (? - my bike is not equipped with ABS)
7: Bulb monitor (confirmed as such on thread with Ned's post)
8: Flasher relay (? - According to Ned's thread, this is the Temp Sens Sw Unit?)
9: Starter relay
Can anyone shed some light here please - where do I find the +12 V supplied to the main cooling fan?
2: Fan
3: Horn
4: Fuel pump
5: Load shed
9: Starter relay
1990 K100 RS (2015 - Current)
2005 R1150 GS - 35000 km (2007 - 2010)
1980 R80 GS - 28000 km (2005 - 2006)
2000 F650 GS - 102000 km (2000 - 2004)
1984 Suzuki Katana 750 - 72000 km (1984 - 1986)
1982 Suzuki DR500 - 48000 km (1982 - 1984)
