1 Fuel injection module gone bad? Sat Oct 10, 2015 1:13 am
tonybob
Hi all -
I have a 1985 K100RS. Rider her to work and back home mostly, only 11 miles each way. Over the summer I had several instances where she'd not want to re-start after riding only a few miles (leave home and stop for gas, for example). Let the bike sit for a few minutes and she'd start no problem. No issues with engine cut-out or missing when running otherwise.
Then, couple of months ago, she stopped completely. Riding home the rpms wanted to drop below 1000 at idle - sitting at a stop light I had to rev to 1500rpm or more to keep it running. Made it home, but in the last couple of blocks one or two cylinders totally cut out and just before I shut down the idle speed was down to 600rpm or so.
Replaced fuel filter, checked all 4 plugs for spark (all good). Bike will crank, but not fire. You can hear the fuel pump spin.
Took her to a vintage mechanic here in Seattle. He checked the injectors and all 4 were spraying fuel, but interestingly would continue to spray for about 2 seconds after releasing the starter button. He diagnosed a failed fuel injection module.
Has anyone experienced anything similar with their bike? I had a quick look at the EFI troubleshooting page in the portal and will be following up with this. Also thinking of buying a used module to see if that helps with the fix.
Thanks,
Tony Marts
Thanks,
Tony Marts
