1Back to top Go down   1992 K75 Custom "Cafe-esq" Empty 1992 K75 Custom "Cafe-esq" Thu Oct 29, 2015 10:38 pm
diesis
diesis
I realize this is a K100 forum, but it does seem to have some excellent project bike resources.  Hopefully my smaller brick will get a bit of respect on here.  I expect to run into most of the same problems everyone else has and I'll do my best to dive through the archives to see what the solutions are.  Electrical will be a fun one for me (as it has been for many others).
Here's what I decided to break
1992 K75 Custom "Cafe-esq" Everno10
It is / was a 1992 K75 with just a hair under 20K on it.  Ran like a top.  I have no excuses on the engine side if it doesn't start up when I put it back together.
Stripped the bike down to get to the frame, wanted to do a few frame cuts and perhaps weld a few items on.  Did a blank background shot to use as a sketchpad.
1992 K75 Custom "Cafe-esq" Dsc_3910
Follow ups to come.  The frame is off and getting modified and the engine paint has been touched up.  Outside of this forum the project can be found on instagram: @diesisphoto #projectk75
1992 K75
2004 GS Adv
2Back to top Go down   1992 K75 Custom "Cafe-esq" Empty K75 Custom continued Thu Oct 29, 2015 11:06 pm
diesis
diesis
Sketchup of the general idea.  A guide, if nothing else.  The white is what will be removed.  Handlebars will be swapped to a much lower pair of Renthals - I don't find the full lean as comfortable so this one will still have a partially upright seating.
1992 K75 Custom "Cafe-esq" Threes10
Used POR 15 to clean up the engine a little bit.  Sorry about the rotation.
1992 K75 Custom "Cafe-esq" Img_3310
I will be replacing the gauges with a motogadget mini and some other accessories (figuring out the wiring will probably take care of my winter).  New LSL headlight and mount.  Planning on re-running upgraded brake lines from Speigler.   Has anyone done the rotor modification that they offer?
1992 K75
2004 GS Adv
3Back to top Go down   1992 K75 Custom "Cafe-esq" Empty Re: 1992 K75 Custom "Cafe-esq" Fri Oct 30, 2015 7:49 am
Rotor modification? For what? I failed miserably trying to find it on their website.
4Back to top Go down   1992 K75 Custom "Cafe-esq" Empty Re: 1992 K75 Custom "Cafe-esq" Fri Oct 30, 2015 8:18 am
Hi Diesis
Its a K forum as much as K100. So its K75 K100 K1100 and some K1200 bricks.
No need to feel you are in the wrong place, quite a few forum members have K75 and K100 bikes tucked away.
Some of your modifications have been done by others so someone will be able to point out the pit falls and answer questions.
Olaf
5Back to top Go down   1992 K75 Custom "Cafe-esq" Empty Spiegler brake rotor conversion Fri Oct 30, 2015 10:47 am
diesis
diesis
Here's the link to the rotor conversion.  Spiegler conversion
Apparently converts to a semi-floating assembly.  Not sure how much value (other than aesthetic) this offers.  I also expect it is 2X the cost for the front, seeing as there are two discs.
1992 K75
2004 GS Adv
6Back to top Go down   1992 K75 Custom "Cafe-esq" Empty Re: 1992 K75 Custom "Cafe-esq" Fri Oct 30, 2015 11:56 am
"What we have here is a failure to communicate."
~Strother Martin, the Captain, Cool Hand Luke
Rotor = brake disc, brake rotor, disc brake...
'Pends on what part of the world you come from. I've noticed, having been here in the US on and off for yonks, that Merkuns tend to use the word rotor when talking 'bout brake discs more than other English speaking countries. It does spin, afterall.
:flower:
7Back to top Go down   1992 K75 Custom "Cafe-esq" Empty Re: 1992 K75 Custom "Cafe-esq" Fri Oct 30, 2015 2:16 pm
Two Wheels Better wrote:"What we have here is a failure to communicate."
Right. So we won't talk about rubbers then?
8Back to top Go down   1992 K75 Custom "Cafe-esq" Empty Re: 1992 K75 Custom "Cafe-esq" Fri Oct 30, 2015 2:22 pm
Motorbike Mike
Motorbike Mike
Looking down Spieglers list I can see at least 6 bikes that already have floating discs from the factory.  🇳🇴
