1Back to top Go down   ABS control unit needed-again!! Empty ABS control unit needed-again!! Mon Sep 21, 2015 10:55 pm
Motorbike Mike
Motorbike Mike
Hi guys,
Once again, I'm in need of an ABS control unit for a '92/93 K1100. I'm pretty miffed at having to try and find another unit.
I've had a diagnostic unit on it and seven flashes of the light confirms it's the control unit at fault.
Does anyone have an ECU they'd be prepared to part with?
Thanks,
Mike.
2Back to top Go down   ABS control unit needed-again!! Empty Re: ABS control unit needed-again!! Tue Sep 22, 2015 1:22 am
Best repairs and a good turnaround time as well
http://bmwk10075abs1fix.web.fc2.com/
3Back to top Go down   ABS control unit needed-again!! Empty ABS brain Tue Sep 22, 2015 1:34 pm
audibob
audibob
Hi Mike, is yours ABS 1.5 ?
as I have a spare brain which I  know works.  I want to keep it as a spare, but you are welcome to pop over and try it on your bike and see what happens.
I am not far from you at J28
Bob.
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
4Back to top Go down   ABS control unit needed-again!! Empty Re: ABS control unit needed-again!! Tue Sep 22, 2015 2:28 pm
Motorbike Mike
Motorbike Mike
Hi Bob,
Thanks very much for your kind offer but I've just checked and my bike has a 2.5 ecu so I'm presuming that's what I'll need.
Mike.
5Back to top Go down   ABS control unit needed-again!! Empty Re: ABS control unit needed-again!! Sun Oct 04, 2015 10:17 pm
GerryP
GerryP
This can be expensive/annoying.
I had my 2.5 unit fixed by our Japanese friend Tosi-san and it worked perfectly for about 18 months - then water got into it... It caused enough damage that I could not send the unit back again.
After looking closely at the abs unit it seems that water can only get in through the holes for the two self-tapping screws, one at each side of the connector, which hold the end on the case. On my next unit I intend to seal these very carefully.
Safe riding Cool,
Gerry Parnham
K1100LT (1993) in Silk Blue/Cream
http://gerryparnham.com
6Back to top Go down   ABS control unit needed-again!! Empty Re: ABS control unit needed-again!! Mon Oct 05, 2015 10:37 am
Motorbike Mike
Motorbike Mike
I sent mine off to Tosi last week.
Thanks for the tip about the water getting into the plastic body. I'll be sorting that potential problem before it goes back on the bike. ABS control unit needed-again!! 112350
