1 how do you test the fuel pressure regulator on a K100 Rt? Tue Sep 01, 2015 5:10 pm
mr lee esq
How can can I test the fuel pressure regulator on my K100 Rt? It still keeps juddering and I've double checked the fuel filter isnt blocked as I replaced it less than a 1000 miles ago as the air filter, and the filter on the end of the fuel pump.It ticks over and starts straight up but when riding it, it struggles to pull through the gears. Also done the exhaust and inlet valves and checked the throttle body rubbers for air leaks and balanced the same. Been all through the electrical connections and earthing points which all seem good. Starting to run out of ideas now?
Thanks Steve.
Thanks Steve.
Last edited by mr lee esq on Tue Sep 01, 2015 6:39 pm; edited 1 time in total (Reason for editing : typing error)
