1 engine hard start Tue May 25, 2010 10:31 pm
cjboy
when engine starts it has to at hot weather and when it starts it is only at a idle. If i give it gas or chock it the engine stops. only after it warms up one can rev it faster and then runs great. when it don't start the plugs are wet after only trying for a short time. when trying to start it sputters then finally will run good. I have changed the EFI unit and checked the fuel pressure and is about 30psi Need help Thanks Cliff
