1 Speedbleeder on ABSI question Thu Sep 03, 2015 12:48 pm
kioolt
I just put speedbleeders on my 91 K100LT front wheel caliper and ABS unit. Everything went fine as far as bleeding goes. I did notice that the OEM bleeder screw on the ABS unit is different than what I call a standard bleeder screw. There is an o-ring to the right of the threads and between the threads and the o-ring is what appears to be a relief cut for fluid flow. Please take a look at the image below. Does anyone know if the speedbleeder is an ok substitute for this and that my ABS will still function as intended?
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
