1 Help! started something big! Sun Apr 04, 2010 10:23 pm
Bruce
Just wanted to lube the drive splines, and keep finding more stuff to fix.
stupid question time,
can I lube the swingarm bearings with the same grease as the drive splines?
My male spline from the transmission into the swingarm is looking very good, but thereis a sharp taper across all the teeth for the last 1/8", is this normal or am i screwed?
the driveshaft U joint didn't have very much grease on it, should I grease it up lots or is that bad? same grease as drive splines?
I'm sure I'll have more questions, will post pics with the questions asap. thanks for your help!!
Cheers B
Cheers B
