1 Remus Innovation exhaust for K100RS 16v Wed May 06, 2015 1:44 pm
mr grumpy
Thank you for any and all advice.
K100RS 16v
KafeRacer wrote:I have one on my Kafe project, and I used the 4 copper gasket rings at the head, but there was not much stud thread left on the studs, if its designed to be used without them, then that would explain it.
Cheers.
Last edited by GerryP on Sun May 17, 2015 1:15 pm; edited 1 time in total (Reason for editing : zpellinks)
GerryP wrote:Oxygen sensors were only fitted to the post-94 k1100 engines.
I guess it depends on the requirements of the market, The '99 K1100LT I stripped to provide an engine for my sidecar did not have an oxygen sensor. I stripped the bike completely, i would have noticed.GerryP wrote:Oxygen sensors were only fitted to the post-94 k1100 engines. Prior to that mixture adjustment on the 16v engines was by using a small, muti-turn adjuster adjacent the fusebox.
Be gentle 'cos its very easy to turn the adjuster off the end of its travel. I use a watchmaker screwdriver to adjust mine.
Getting the mixture right makes a big difference to the fuel consumption (from 40 to 60mpg(imp) on a run).
GerryP wrote:Does that mean I can install an o2 sensor on my Motronics 2.1 K1100?
Motronic 2.2 was released no earlier than production month 7 of '93 model K1100 in all markets, with or w/o catalyst. Prior to that month they were Motronic 2.1 with or w/o catalyst.GerryP wrote:Motronics 2.2 (o2+cat) could appear on any K1100 from 1991 onwards depending on the market and mood of the original purchaser...
Two Wheels Better wrote:What's the VIN (last seven) of your K100-16V? I'll run it through The Great Computer and see what it might have come with from die Fabrik.
Your Royal Blau (680) K100RS, built in 11/12 of 1991 came with factory Engine Spoiler in Silver (0566), Temp/Fuel Gauge (0721) and ABS (0524), and was sold as new by Heid's Hodaka in Johnsburg, New York on Friday, 21 August, 1992.Point-Seven-five wrote:6494026Two Wheels Better wrote:What's the VIN (last seven) of your K100-16V? I'll run it through The Great Computer and see what it might have come with from die Fabrik.
So is this the difference from the green to orange label.Inge K. wrote:On the unit it would be marked with the last five digits w/o spaces 1464607.
It would also be a green Bosch label with the part # 0 261 200 270.
RicK G wrote: So is this the difference from the green to orange label.
Last edited by mr grumpy on Fri May 22, 2015 12:04 pm; edited 1 time in total (Reason for editing : Photographs added)
Is this the mixture adjust screw ?
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Remus Innovation exhaust for K100RS 16v
Similar topics
