1Back to top Go down   1990 K100 RS 16V ABS MODEL Empty 1990 K100 RS 16V ABS MODEL Sun Jul 05, 2015 9:09 am
marknico
marknico
Hi after abit of advice, I`ve noticed a wire from underneath bike comes out of a circle near main stand it`s not connected to anything and appears to be a 2 core wire enclosed in a black sleeve seems to run up by the coolant expansion tank area ?  Cheers
2Back to top Go down   1990 K100 RS 16V ABS MODEL Empty Re: 1990 K100 RS 16V ABS MODEL Sun Jul 05, 2015 9:47 am
Your bike should have a side-stand switch that disables the fuel pump when the side-stand is down.
If you can start the bike with side-stand down then this cable may be what is left over after someone disabled it.
1990 K100 RS 16V ABS MODEL Ir-log10
 ;BMW; K1200RS Red
3Back to top Go down   1990 K100 RS 16V ABS MODEL Empty Re: 1990 K100 RS 16V ABS MODEL Sun Jul 05, 2015 11:33 am
marknico
marknico
Ringfad wrote:Your bike should have a side-stand switch that disables the fuel pump when the side-stand is down.
ok thankyou I ll see if it starts with stand down then that ll be the wire I guess Very Happy
