1 No power & Clutch noise when it's engaged. (IUpdate: Fixed) Mon Jun 15, 2015 2:48 pm
TheJoker
I know this has already been posted before however I was basically wondering where to start. Basically I was riding today like normal just filled up a little bit too much (that was sorted). Came to a bend and lost power there was like a grinding noise coming from the bike. Here is the noise not that good of a file though;
Clutch sound noise clip.
Wondering what had happened I pulled over, tried to go again however there is no power, it revs cleanly (in neutral) and goes into every gear if not turned on, . However when I pull in the clutch it makes the noise and won't move.
Now I don't mind pulling the clutch and pulling at straws however I was wondering if one of you have come across something similar before (which might narrow my field down a bit)
Edit: Also found a crack in the I believe breather hose but I think that may have been there a while. For the engine breather.
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
