1Back to top Go down   K100 restoration cafe-racer style  Empty K100 restoration cafe-racer style Sat Jan 18, 2014 3:07 pm
Cossie
Cossie
Having spent many months looking for a project I recently purchased a  K100 RT that needs work.  (Built 10-1984)
The seller had inherited it as an incomplete rebuild. It was not running and it was not clear what parts were missing . The price was good so i took a chance.
What i brought home.
K100 restoration cafe-racer style  Hpim0410
K100 restoration cafe-racer style  Hpim0411
I sourced the following missing bits from a local breakers
Injectors
Cam cover bolts
HT leads
HT coil
I checked the torque on big end bearing and main bearing bolts and they were OK (it was not clear what had been taken apart , what had been put together properly and what had been hastily reassembled by the PO when moving the bike)
I removed spark plugs plugs, squirted oil into the cylinders and onto crank bearings. Left it for a while then pushed the bike in gear and the engine rotated OK.
I dumped the fuel that was in the petrol tank  and rinsed it a few times with fresh petrol then put more fresh petrol in. Oil and water in the engine. Oil in gearbox and final drive.
From what i have read when starting an engine that has been sitting a long time the important thing is to get it running as promptly as possible to get oil circulating under pressure.
So i tested the injectors separately with a 9V battery and a syringe of alcohol and the all looked good.
I hooked up a battery and turned the engine over with plugs out and was getting a good spark. Also oil pressure light went out which was reassuring.
Time to go for it.
Connected everything up pressed start and with in less than 10 secs it fired. A few more goes and it was running. Result! It sounded nice and smooth too. There was an awful lot of smoke and a knock that on first guess sounded like  a big end bearing, but it was running.
I left it running for for about 40 mins until the fan cut in.
I started and ran it a few more times and over time  the smoke disappeared. (the knock did not)
I also carried out a compression test and all 4 cylinders were good.
At that stage I was able to say that the engine was worth stripping down to refurbish.
Initially the plan was a cafe racer style rebuild. This is what i had been looking at
K100 restoration cafe-racer style  Bmw-k110
K100 restoration cafe-racer style  Img_3110
K100 restoration cafe-racer style  Sam_0211
K100 restoration cafe-racer style  Sam_0212
K100 restoration cafe-racer style  Sam_0310
However when i got the bike it looked really good as original so i carried out a few trials to lower the original seat. No matter what i did i was not comfortable sitting on the bike at a stop. The seat is just too wide and too high for me (I am not tall) so back to original plan .
I mocked up  a few seats in cardboard and when i had one i liked i did a prototype in plywood.
I put this on the bike and with a new battery fitted i took it for a spin up and down the lane (about a mile) This allowed me to test operation of the clutch and gearbox (all good).  It was only a 10 minute spin on the bike but i could not stop grinning all evening.
After the first "Road Trip"
K100 restoration cafe-racer style  Hpim0414
K100 restoration cafe-racer style  Hpim0415
K100 restoration cafe-racer style  Hpim0416
K100 restoration cafe-racer style  Hpim0417
First  the mods to frame
Shorten rear overhang and fabricate new cross brace/Lights and seat support. Two new blanking plugs for rear of frame bonded in with epoxy. New fuel tank mounting cross piece.  Remove redundant brackets from frame.
Then dismantle bike as per Bert's excellent article.
Frame ready to be sent for blasting and priming.
K100 restoration cafe-racer style  Dscf0010
K100 restoration cafe-racer style  Dscf0011
Frame back after blasting and etch primer
K100 restoration cafe-racer style  Dscf0012
Next I applied 3 coats of rattle-can  Simoniz acrylic satin black
K100 restoration cafe-racer style  Dscf0013
Its not perfect but the satin is fairly forgiving and i think it looks well.  Its should allow for easy touch up if and when need in later life. As long as it is durable and does not start to rust i will be happy. Time will tell.
That's all for now.
Last edited by Cossie on Sat Feb 08, 2014 3:02 pm; edited 4 times in total (Reason for editing : Inserting pics instead of links)
MikeP
MikeP
Looking good. I'm just finishing off painting another frame. They're a pain to get right without overloading some tubes with paint aren't they?
If you type in the image tags at either end of your links: the image will appear (as above).
1992 K1
GTJos
GTJos
Very Happy Hi Cossie !
Looking good; happy to see you started with a solid base !
In regards to the paintjob: my compliments. I'm lucky enough to have a son who's a pro (makes a living being an allround painter).
I watched him sanding, filling, priming, masking and spraying cars and bikes many times, but I agree with MikeP: it's a hell of a job to get a bike's frame just right ! So: compliments on this one, keep up that good work !
I'll be following this project with interest; thank's for sharing !
Regards
Jos
K100 restoration cafe-racer style  Deutch10Ich bin enge Kirchröatsjer jong; adieë wa ?! K100 restoration cafe-racer style  Deutch10
                                1992  K1100LT 6458188
                                1987 K100LT (RS-fairing) 0170844 + sidecar EML GT2001
                                1986 K100RS 0085647 + sidecar Velorex 562
                                1985  K100RT  0027026
4Back to top Go down   K100 restoration cafe-racer style  Empty Engine output shaft rivets Tue Jan 28, 2014 5:34 pm
Cossie
Cossie
Thanks for the comments.
I have opened the engine to get a look at the output shaft as it seemed the most likely source of nasty noise. I found that the rivets were indeed loose.
I sourced a replacement from a motor breakers on E bay (from a 1987 K100 LT)
Yesterday I got the lend of some bearing pullers and was able to get a better look at the original and "new" shaft
These pictures are the original shaft
K100 restoration cafe-racer style  Dscf0110
K100 restoration cafe-racer style  Dscf0111
K100 restoration cafe-racer style  Dscf0112
It appears to me that over time the hole in the anti-backlash spring that engages with the pin on the narrow gear wears and  opens up. As this happens the spring can move outwards and starts to hit the sides of the Rivets. In my case the three leftmost rivets are loose (i can rotate them easily)and 2 have been marked on the side where the spring has been hitting them.
K100 restoration cafe-racer style  Dscf0113
In contrast, the newer type spring which is fitted to the 87 shaft is much smaller and even if it wears a bit it is never going to impact the rivets.
That is the one i think i should be fitting.
5Back to top Go down   K100 restoration cafe-racer style  Empty New output shaft Sat Feb 08, 2014 3:10 pm
Cossie
Cossie
Output shaft ready to go in. I got this second hand on E-Bay and fitted a new bearing and new spring in the anti-backlash gear.
K100 restoration cafe-racer style  Readyt10
6Back to top Go down   K100 restoration cafe-racer style  Empty Re: Engine output shaft rivets Sat Feb 08, 2014 8:05 pm
GTJos
GTJos
Very Happy Fine pictures, thanks for that !
Always good to have this kind of documentation, as 1 picture "says" more than 100 words.
Cheers !
Jos.
                                1985  K100RT  0027026
Oldgoat
Oldgoat
Beautiful work on the frame!  Do you mind if I ask what you payed for the OP shaft on Fleabay?
OG
8Back to top Go down   K100 restoration cafe-racer style  Empty Output shaft Sun Feb 09, 2014 4:41 am
Cossie
Cossie
Thanks guys
I got it for £20.00 plus £10.00 for shipping which i think was very reasonable.
This is the store
http://stores.ebay.co.uk/moto-partz?_trksid=p2047675.l2563
Cossie
Cossie
Finally starting to put things back together!
K100 restoration cafe-racer style  Dscf0115
floyd
floyd
Cossie wrote:Finally starting to put things back together!
Oooooh I cant wait til I put my frame back on!
Looking good mate!
lots of potential ...good work
GTJos
GTJos
Cossie wrote:Output shaft ready to go in. I got this second hand on E-Bay and fitted a new bearing and new spring in the anti-backlash gear.
 Smile Hi Cossie !
Congrat's; hope you get her back together before this season ends ? Thumbs up !
And also: thank's to your earlier remark about the 'anti-backlash gear' I'm now pretty sure of the sound-source coming from my engine ! Since a few weeks, mostly right after a cold start, I hear a kind of 'hickup' -accompanied by a split-second drop of the idle-. No problem on higher than idle-revs, she's running as smooth as she ever did but the 'hickup' at idle stays.
Seams to me that I'm in for some rebuilding, coming winter ! (Sorry for hijacking your threath a little...  Very Happy
Keep on the good work !
Jos
                                1985  K100RT  0027026
Cossie
Cossie
Thanks for the comments guys.
I now have the bike back together enough to start her up and take for a spin up the road
Feels great.
K100 restoration cafe-racer style  Dscf0311
Looks like you got the genuine factory mounted shock absorber,
and it's mounted upside down.
Cossie
Cossie
Inge K. wrote:Looks like you got the genuine factory mounted shock absorber,
Thanks Inge
I shall attend to that.
floyd
floyd
does the red alternator go faster? Wink
good luck with the start
Cossie
Cossie
floyd wrote:does the red alternator go faster? Wink
Nice one  Floyd
The red alternator was the previous owners attempt at detailing.
I have removed red paint from the starter, as well as engine mounting bolts and various other bits and pieces. The alternator has yet to be done.
I see you are in Marrickville. I have great memories of a year I spent a  working at Unilever (Edinburgh Rd) back in the 90's. Met some really sound people.
18Back to top Go down   K100 restoration cafe-racer style  Empty A few more photos Sun May 25, 2014 7:30 am
Cossie
Cossie
Front headlight fitted
Front indicators fitted
Front brakes working
Back brakes working (sort of)
Drives and runs well
I have had it up and down the road a few times now and am starting to get used to the weight of it.
I am treating the seat as a "Revision 1" as i suspect it may not be that comfortable for long journeys (or even short ones)
There is a bump from the front going over rough spots on the road  so i think will need to readjust the steering bearings
K100 restoration cafe-racer style  DSCF0374_zps420f0510
K100 restoration cafe-racer style  DSCF0373_zps4c5b236c
K100 restoration cafe-racer style  DSCF0368_zps46546920
K100 restoration cafe-racer style  DSCF0367_zpseb23ad40
K100 restoration cafe-racer style  Cbbe8236-3583-4e13-9694-c1c41083e7b5_zps9e513b18
K100 restoration cafe-racer style  696ceab7-2b86-4934-9107-80023fe93e95_zpsd459bfb5
K100 restoration cafe-racer style  F2b46790-44f7-484e-805a-1e7d9a6924c7_zps24d5a0bb
Comberjohn
Comberjohn
Taking shape.
I notice you have left the 'snorkel' off the air box.
Seem to remember a while ago on a thread. Someone remarked that air passing over the hole in the air box when going faster, could cause negative or low air pressure in the air box.
While the snorkel isn't pretty, it does give a bit of a ram effect at speed.
The stock silencer looks enormous when the rest of the bike is stripped down!
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
Tenox
Tenox
I do not have that snorkel and the bike performs very well without it too. Standing mile (naked bike, large pilot) with my humble acceleration skils with end speed 197km/h and bike would have continued to accelerate but the runway ended.
I do have a little home made shield on it.
Like this:
https://www.dropbox.com/sh/wso2wf0jajx9dju/Us9IpM3PD1#lh:null-PC13_01.JPG
and from airport:
https://www.dropbox.com/sh/wso2wf0jajx9dju/Us9IpM3PD1#lh:null-1stRun.jpg
BMW K100RT Scrambler (86)
bryandarragh
bryandarragh
Excellent, I envy your skills
BMW K100RS 8 valve
1986
Cossie
Cossie
K100 restoration cafe-racer style  20150710
Well finally got the bike on the road. A small matter of getting a licence had to be overcome. Insurance was sorted on Friday . So far 160 Kms (Small local trips). Am very happy indeed. I have to say a big thank you to  all the contributors to this forum as without it  I could never have completed this project . Thanks again.
Comberjohn
Comberjohn
Congratulations on getting on the road at last.
Was down your way weekend before last after coming down the coast from Sligo.
You have some great scenic roads around you, but try to keep her between the hedges until you get used to it.
Plenty of tourists in hire cars!
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
