TheJoker
TheJoker
Hello I recently pulled the sprag clutch to clean on my k100rs 1984. However upon completing the job I didn't have a torque wrench up to 140ftlb. So used one that went up to 110 and did it a bit extra on the output shaft nut. Now the o ring on the output shaft has gone. The replacement from motor bins was thinner than the original. Just wondering as I've got the bike apart. Is there a knack to stop it from giving way. Or was it the fact that it wasn't up to 140ftlb.
TheJoker wrote: However upon completing the job I didn't have a torque wrench up to 140ftlb. So used one that went up to 110 and did it a bit extra on the output shaft nut. Now the o ring on the output shaft has gone. The replacement from motor bins was thinner than the original.
Not enough squeeze can contribute to o-ring failure. Correct torque values should be used. You could also have received an incorrect part. You should confirm dimensions and part numbers with the supplier.
It isn't 140 ft/lb, but 140 Nm (which is much lower)...and that is 1st stage.
Second stage is: loosen the nut and retighten to 100 Nm.
TheJoker wrote: The replacement from motor bins was thinner than the original.
The o-ring should be 19x4 mm.
At least you won't need a different torque wrench, Joker! cheers
TheJoker
TheJoker
Sorry I was looking at the output shaft when writing this, I've only just started using torque settings so forgot which way around it was. It was tightened relased then tightened again obiously not enough as its leaking. This is the output shaft as you can barely see (it's a bad photo) the pot of oil below the shaft. Regarding the O ring I'm not sure if it seemed bigger (thicker) because it was flattened.
For some reason the image has rotated can't change it.
Sprag clutch sorted but the seal has given way 20170411
Sprag clutch sorted but the seal has given way PixelSprag clutch sorted but the seal has given way PixelSprag clutch sorted but the seal has given way Pixel
My Bike List past to present so far;
Lexmoto (first bike ever to ride) , CB125 TDC 86 , CG125 89 , GN125 97 , ER5 96 , K100 RS 84
84/01 K100rs 0013627
