Technical, repair and troubleshooting
Forum | Topics | Posts | Last Posts |
Electrical | 2181 | 26936 | restoration of t... Thu Nov 21, 2024 2:01 pm glennpm |
Frame, fairing and wheels | 1692 | 18541 | Lighting upgrade... Today at 10:16 am Tranberg |
Engine and transmission | 2173 | 29876 | Idling problem... Mon Nov 18, 2024 9:54 am glennpm |
How to – Article from you telling others how to do a specific job | 219 | 1891 | The ultimate BMW... Fri Oct 25, 2024 1:45 am David Menzies153 |
Other K bricks (K75, K1100, K1) General discussion. | 263 | 3205 | cooling fan fuse... Mon Nov 18, 2024 5:31 pm tinyspuds |
Special tools and jigs | 75 | 847 | K Bike valve adj... Mon Jul 29, 2024 11:56 am Point-Seven-five |
Everything about adding a chair(sidecar) on a K Bike..... | 137 | 1991 | The ultimate sid... Sun Oct 13, 2024 5:58 pm Dai |
K bikes and trailers | 12 | 162 | Adding a Kamper ... Mon Oct 09, 2023 5:01 am Tranberg |
Topics [0]
What else can I do to "revamp/restore" my k100lt?by colinijohnsonHi everyone - comments/suggestions very welcome please | 3 | 1658 | Mon Oct 08, 2012 1:46 pm by club_c |
Cooling system issues[ 1, 2 ] by Dirk Diglerrelay identification | 55 | 8882 | Sun Oct 07, 2012 5:48 pm by Dirk Digler |
1988 K100LT torque values needed pleaseby Farzand Shergill1988 K100LT torque values needed please | 6 | 1735 | Sun Oct 07, 2012 5:48 am by Inge K. |
K100 project final stages (?)by GuestTail light stays on | 22 | 2708 | Sun Oct 07, 2012 3:52 am by Inge K. |
Changing fork oilby Richard1 | 48 | 5474 | Mon Sep 24, 2012 12:00 am by andyb |
ABS Helpby mikidymacRear ABS does not work | 7 | 1846 | Sat Sep 22, 2012 8:41 pm by Rick G |
1989 K100 RTIC Broken down in Spain.by GARYSTIGER955i | 15 | 2317 | Sat Sep 08, 2012 6:25 pm by K-BIKE |
Filling radiatorby marten | 3 | 2399 | Sun Sep 02, 2012 2:48 am by marten |
on-off-on starting problem - ignition module or hall sensors??by ReneZDay 7 - the Nuerenberg ring and a bit of Mosel | 8 | 3663 | Wed Aug 29, 2012 12:53 pm by ReneZ |
Best Practice *Preventative* Maintenance Tips?by zaubertuba | 4 | 2018 | Tue Aug 21, 2012 4:45 pm by Inge K. |
Ethanol free gas in New York Sate.by Brickee | 2 | 4506 | Tue Aug 14, 2012 11:55 pm by Two Wheels Better |
k100 rtic fork seals and bootsby hector2does anyone know which seals the rtic takes? | 3 | 1915 | Mon Aug 06, 2012 10:08 am by Rick G |
Brake Squealby lhead71 | 19 | 5045 | Thu Aug 02, 2012 6:38 pm by STEVE1959 |
air flow sensor readings ?by sven k100 | 3 | 2954 | Thu Aug 02, 2012 9:21 am by charlie99 |
Bike won't start after running fine for two weeksby lhead71 | 30 | 4023 | Thu Jul 26, 2012 11:49 am by nutheastah |
Goodbye Kayby Terry Dactyl | 6 | 1991 | Fri Jul 20, 2012 6:54 pm by Inge K. |
Overheatingby Lucky LouWhich relay | 8 | 2342 | Thu Jul 19, 2012 5:05 pm by ReneZ |
Help me remember a K100 testby 2slow | 3 | 2194 | Thu Jul 12, 2012 1:53 pm by 2slow |
Fuel consumption questionby John The Hat | 2 | 1909 | Wed Jul 11, 2012 10:02 pm by Rick G |
Gas gauge stopped workingby Schatzi03 | 3 | 1909 | Fri Jul 06, 2012 6:41 pm by Inge K. |
10 Liter for 100Km, is too much..?!by Bazsimoci | 6 | 4282 | Wed Jul 04, 2012 5:48 pm by Bazsimoci |
Engine running but won't switch off by keyby KJBK100RS 1984 | 5 | 2022 | Tue Jul 03, 2012 7:44 pm by Inge K. |
Noisy fuel tank non return valve on 1984 K100RSby KJBNoisy! | 5 | 3583 | Tue Jul 03, 2012 12:12 pm by KJB |
1985 K100 drive shaft/U-Jointby rwiley111Bearing Number | 7 | 3074 | Fri Jun 29, 2012 2:34 pm by rwiley111 |
Bad center stand?by Puccini | 9 | 2679 | Sat Jun 23, 2012 6:46 pm by K-BIKE |
Radiator overflow tank level gauge tube thingby ianburgess | 11 | 6934 | Sun Jun 17, 2012 5:35 am by Two Wheels Better |
Round K&N air filter for air sensor.by Jumpmaster | 1 | 1667 | Fri Jun 08, 2012 12:19 am by Rick G |
front brake leverby joemreplacment | 5 | 2301 | Mon Jun 04, 2012 1:21 pm by sidecar paul |
Can you lower the ride height of a 1990 K100LT?by kj6304 | 7 | 3292 | Sat Jun 02, 2012 9:50 pm by Two Wheels Better |
dissapearing fuel pressureby sven k100 | 1 | 1891 | Thu May 31, 2012 6:27 am by Inge K. |
Do I need a C-Spannerby wombat2540 | 11 | 2895 | Fri May 25, 2012 5:54 am by Lazyboy |
Cooling Systemby BEEJAYRadiator Leak | 10 | 2484 | Mon May 21, 2012 6:08 pm by Hover K100 |
Cleaning Insects Out of Radiatorby MLR | 7 | 2288 | Mon May 07, 2012 12:23 am by MLR |
Does anyone know what this is?by STEVE1959 | 9 | 1871 | Tue May 01, 2012 8:41 pm by STEVE1959 |
Integral Cases recessed Rivet holes don't fit the head of the gun...hmmm bolt it?by TSBT | 10 | 3024 | Tue Apr 24, 2012 8:14 am by RT |
Flooding K100by aquachrono23 | 27 | 5747 | Sat Apr 14, 2012 9:37 pm by Inge K. |
Cooling System has lost its primeby FreebasserSFCooling system not pulling water from overflow bottle | 33 | 2417 | Tue Apr 10, 2012 10:12 am by japuentes |
What is the bolt on the front of my 1992 k100rs engineby krome | 4 | 2266 | Wed Apr 04, 2012 2:35 pm by krome |
Copper Slip and CV Joint Greaseby Lazyboy | 3 | 3681 | Sat Mar 31, 2012 11:22 pm by K-BIKE |
K1100 questionby Comberjohn | 3 | 1817 | Sat Mar 31, 2012 8:44 pm by Rick G |
Brake issues?by ReneZBrakes not releasing properly?? | 5 | 2129 | Sat Mar 31, 2012 4:17 pm by K-BIKE |
Bike wont start, only clickby fearlesspk | 19 | 2152 | Sat Mar 17, 2012 5:50 am by col |
Gearbox Bummer. Rebuild/Overhaulby Albyalbatross1 | 41 | 4541 | Fri Mar 09, 2012 4:29 pm by K-BIKE |
Rear Brakeby snave | 3 | 2173 | Wed Feb 29, 2012 5:13 pm by Inge K. |
Paint bubbles on tankby gmlc | 6 | 2051 | Fri Feb 17, 2012 8:07 am by gmlc |
Draining the fuel tank.by Steve75 | 15 | 2784 | Sun Feb 05, 2012 8:44 am by Inge K. |
clutch cableby joem | 2 | 2150 | Sat Feb 04, 2012 12:31 am by WayneDW |
How to balance throttle bodies ?by Buckiemick | 8 | 3061 | Tue Jan 17, 2012 7:53 am by zonenfeile |
Alternative oil filterby Dennis | 12 | 4156 | Fri Jan 13, 2012 12:04 pm by Moto Smith |
Hi all advice neededby timmy1987 | 14 | 1917 | Sat Jan 07, 2012 3:58 pm by K-BIKE |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
