Technical, repair and troubleshooting
Forum | Topics | Posts | Last Posts |
Electrical | 2181 | 26936 | restoration of t... Thu Nov 21, 2024 2:01 pm glennpm |
Frame, fairing and wheels | 1692 | 18541 | Lighting upgrade... Today at 10:16 am Tranberg |
Engine and transmission | 2173 | 29876 | Idling problem... Mon Nov 18, 2024 9:54 am glennpm |
How to – Article from you telling others how to do a specific job | 219 | 1891 | The ultimate BMW... Fri Oct 25, 2024 1:45 am David Menzies153 |
Other K bricks (K75, K1100, K1) General discussion. | 263 | 3205 | cooling fan fuse... Mon Nov 18, 2024 5:31 pm tinyspuds |
Special tools and jigs | 75 | 847 | K Bike valve adj... Mon Jul 29, 2024 11:56 am Point-Seven-five |
Everything about adding a chair(sidecar) on a K Bike..... | 137 | 1991 | The ultimate sid... Sun Oct 13, 2024 5:58 pm Dai |
K bikes and trailers | 12 | 162 | Adding a Kamper ... Mon Oct 09, 2023 5:01 am Tranberg |
Topics [0]
Can normal Buna-N oring be used in cooling system?by robmack | 3 | 2138 | Mon Sep 02, 2013 9:32 pm by Rick G |
Success on two fronts!by Ken F | 4 | 1568 | Tue Aug 27, 2013 3:33 am by AL-58 |
Kill that dreadful rattling noise (3,700-4,500 RPM)by Beemer WheelerK-100 "secondary vibration". | 12 | 1923 | Tue Aug 20, 2013 8:08 pm by Beemer Wheeler |
Mystery final drive spline lube??by ltisz | 3 | 1773 | Thu Jul 25, 2013 6:07 am by ltisz |
Fork sealsby Dazco | 3 | 2931 | Tue Jul 16, 2013 9:19 pm by Rick G |
Crooked bars 86 k100by Flip2 | 4 | 1336 | Tue Jul 09, 2013 6:41 am by MikeisonTV |
Top Case Locked - And I can't get it unlocked...by PacNW_85 | 11 | 1940 | Sat Jul 06, 2013 10:21 am by k75RT Keith |
1985 K100RS not running rightby KiltedK100I need some help, I've corrected a number of issue and it's still not happy | 6 | 2294 | Mon Jul 01, 2013 8:55 pm by ibjman |
hELP! pARTS IDENTIFICATION PLEASEby Be made | 4 | 1538 | Mon Jul 01, 2013 5:05 pm by Be made |
Clutch splines/ Rear main seal/ 86 K100by Flip2oil leak transmission area | 4 | 2296 | Sat Jun 29, 2013 12:17 am by Flip2 |
Running the engine without ignitionby Erman | 2 | 1426 | Wed Jun 26, 2013 5:22 am by Erman |
Coolant and Starting Issuesby mountainmania1965 K100 Standard | 2 | 1438 | Wed Jun 19, 2013 5:07 am by Erman |
1986 K100 cold start issuesby Guest | 7 | 2017 | Wed Jun 05, 2013 6:59 pm by Guest |
86 k100 not startingby Flip2new fuel pump wiring/ loosening final drive bolts | 10 | 1844 | Sun Jun 02, 2013 2:39 am by Flip2 |
injectorsby Rob Roy Mcgregor | 19 | 2878 | Sat Jun 01, 2013 8:45 pm by RT |
Looking for ideas for replacement fuel pump for 1991 k100by jrs1983 | 40 | 10139 | Fri May 24, 2013 11:17 pm by MikeisonTV |
Bit of oil on floor from rear driveby Dazco | 9 | 1754 | Sat May 18, 2013 12:30 pm by Dazco |
Choke labeled wire connector under the left side (clutch side) of the tank?!?!by MikeisonTVchoke | 5 | 1961 | Thu May 16, 2013 3:52 pm by Ringfad |
Rad to coolant bottleby the.postman | 5 | 1428 | Thu May 16, 2013 1:44 pm by the.postman |
Abs or rather lack ofby Dazco | 5 | 1658 | Thu May 09, 2013 8:44 am by Dazco |
K1100 Fuel Pumpby gmcqNoisy | 13 | 5936 | Wed May 01, 2013 8:23 pm by Rick G |
Fuel filter list (Found on motobrick.com)by MikeisonTVAlternative fuel filter list for k100 bikes | 1 | 2803 | Mon Apr 29, 2013 4:51 am by Rick G |
Throttle cable adjusterby ali2908 | 0 | 1606 | Wed Apr 03, 2013 5:39 pm by ali2908 |
Rubber sleeveby JOINYMAN | 43 | 4345 | Fri Mar 29, 2013 12:06 pm by japuentes |
Stiff Throttleby mountainmaniaStiff Throttle | 13 | 2177 | Fri Mar 29, 2013 8:51 am by blaKey |
Tyre sizeby JOINYMAN | 12 | 1926 | Thu Mar 21, 2013 5:22 am by Guest |
91 k100rs throttle locking boltby 2slow | 3 | 1695 | Fri Mar 01, 2013 3:26 pm by Inge K. |
Front forks mudguard mount boltsby Fentible | 13 | 2389 | Fri Mar 01, 2013 2:12 pm by Fentible |
What do you call the little bit on the end of the clutch cable that goes into the lever?by Rendrag | 9 | 2388 | Wed Feb 27, 2013 4:44 am by Rendrag |
Original Tool kitby AlhengK100 Tool Kit | 2 | 1463 | Sun Feb 24, 2013 7:36 pm by Alheng |
[solved]85 K100 will not startby Giddyup | 6 | 1990 | Thu Feb 07, 2013 6:40 am by 88 |
Fuel pump or relays ?by ausbrick | 3 | 1699 | Thu Jan 31, 2013 3:26 pm by sidecar paul |
K100 dies when closing throttle.. Only starts after completely stoppingby Rendrag | 44 | 3941 | Sat Jan 19, 2013 6:54 am by Inge K. |
Nylon strap tire mounting.by weez | 3 | 2185 | Wed Jan 16, 2013 1:22 pm by sven k100 |
fuel consumptionby colinijohnsonusing premium fuel | 13 | 7940 | Fri Jan 11, 2013 6:48 pm by Tenox |
Intermittent loss of power and hard startby RT | 6 | 2053 | Tue Jan 08, 2013 5:26 pm by RT |
ABS v1.5 things (Aaaaagh!!)by Rickmeister | 5 | 1701 | Tue Jan 08, 2013 9:43 am by TrikkeK100RS |
partlist leakair problem K75-K1100by zonenfeile | 0 | 1341 | Wed Nov 28, 2012 9:53 am by zonenfeile |
One more question RE Final Driveby coopz1985 K100RS | 2 | 1439 | Mon Nov 26, 2012 6:41 pm by coopz |
Water in Final drive casingby coopzK100 RS 1985 | 3 | 1413 | Mon Nov 26, 2012 12:32 am by coopz |
ABS - Speedo sensor interactionby Rickmeister | 6 | 1781 | Thu Nov 22, 2012 7:17 pm by Stan |
advice needed for my bmw k100rs16vby toecutterbike occasionaly cuts out and backfires | 10 | 1925 | Fri Nov 16, 2012 6:44 am by toecutter |
Confirming spark and fuel pressure the hard way.by weez | 22 | 2053 | Thu Nov 08, 2012 7:25 am by charlie99 |
sudden death for my k100...or is it just sleeping?by diversity48suddenly won't start | 18 | 3526 | Tue Nov 06, 2012 2:01 pm by diversity48 |
inaccurate speedoby hulliojames | 14 | 1928 | Mon Nov 05, 2012 3:03 am by rosskko |
Brakes ??by marten | 8 | 2031 | Sun Nov 04, 2012 2:35 am by Inge K. |
K75 Fluidblocby weez | 2 | 2024 | Thu Nov 01, 2012 6:52 pm by weez |
HELP - I've messed up my speed sensorby colinijohnsonadvice needed | 9 | 2568 | Wed Oct 24, 2012 4:48 am by Ed |
Riding Lightsby the.postman | 8 | 1918 | Wed Oct 24, 2012 12:03 am by Rick G |
how do you tell a 8 from a 16 without pulling the top off?by bigtel | 4 | 1711 | Tue Oct 16, 2012 5:05 pm by bigtel |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
