Technical, repair and troubleshooting
Forum | Topics | Posts | Last Posts |
Electrical | 2181 | 26936 | restoration of t... Thu Nov 21, 2024 2:01 pm glennpm |
Frame, fairing and wheels | 1692 | 18541 | Lighting upgrade... Today at 10:16 am Tranberg |
Engine and transmission | 2173 | 29876 | Idling problem... Mon Nov 18, 2024 9:54 am glennpm |
How to – Article from you telling others how to do a specific job | 219 | 1891 | The ultimate BMW... Fri Oct 25, 2024 1:45 am David Menzies153 |
Other K bricks (K75, K1100, K1) General discussion. | 263 | 3205 | cooling fan fuse... Mon Nov 18, 2024 5:31 pm tinyspuds |
Special tools and jigs | 75 | 847 | K Bike valve adj... Mon Jul 29, 2024 11:56 am Point-Seven-five |
Everything about adding a chair(sidecar) on a K Bike..... | 137 | 1991 | The ultimate sid... Sun Oct 13, 2024 5:58 pm Dai |
K bikes and trailers | 12 | 162 | Adding a Kamper ... Mon Oct 09, 2023 5:01 am Tranberg |
Topics [0]
Idle increase when hot[ 1, 2, 3 ] by RT | 108 | 7794 | Fri Aug 15, 2014 7:35 pm by RT |
Wiring in a aftermarket digital tachometerby MikeisonTV | 2 | 2694 | Thu Aug 14, 2014 10:57 pm by MikeisonTV |
A lucky breakdownby AL-58 | 5 | 1583 | Tue Aug 05, 2014 6:49 am by AL-58 |
3000 revs+ muffler vibesby Gordon SmithK100rt | 0 | 1396 | Wed Jul 30, 2014 3:04 pm by Gordon Smith |
Replace switchgear K 75by Sagi | 5 | 1628 | Thu Jul 24, 2014 6:30 pm by Sagi |
Suggestions for gas cap replacement?by MikeisonTV | 0 | 1378 | Tue Jul 15, 2014 3:04 pm by MikeisonTV |
How hard can it be to change an air filterby Mike101 | 12 | 2265 | Sun Jun 29, 2014 3:56 am by 92KK 84WW Olaf |
link to kbike tech page--bigby garywalker1946tech page link | 1 | 1883 | Thu Jun 26, 2014 7:30 am by Ed |
tune up and adjustmentsby Puccini | 7 | 4489 | Sun Jun 15, 2014 9:26 pm by robmack |
help ! handling issues with radialsby colinijohnsonbt023 110 front & Avon assuri rear 140 | 9 | 1738 | Mon May 19, 2014 10:18 am by charlie99 |
Differences in RS fairings :RESOLVEDby colinijohnsonBet 2 & 4 valve models | 0 | 1484 | Sun May 18, 2014 7:08 pm by colinijohnson |
Help identify these clips - 1987 K75Cby robmack | 4 | 1656 | Tue May 13, 2014 9:16 pm by Rick G |
K100 having an issueby MikeisonTV | 4 | 1601 | Tue May 06, 2014 7:53 pm by 92KK 84WW Olaf |
rear masterby kartooo | 8 | 1683 | Mon May 05, 2014 5:47 pm by kartooo |
Low RPM'sby marten | 5 | 1515 | Mon May 05, 2014 12:54 am by marten |
Fuel pump breather tubeby JGT | 2 | 1590 | Sat May 03, 2014 7:58 pm by kartooo |
moly paste, twist grips and sticky throttleby Ned | 4 | 1793 | Wed Apr 23, 2014 10:48 pm by Ned |
Should you lube new oil seals before fitting?by grantf2 | 8 | 2578 | Tue Apr 15, 2014 9:27 pm by Rick G |
Fuel pumpby dowdytom | 10 | 2415 | Mon Apr 14, 2014 10:29 pm by dowdytom |
the beginningby k-wopper | 11 | 1597 | Mon Apr 14, 2014 5:22 pm by k75RT Keith |
FITTING OF TEMP & OIL PRESSURE GAUGESby bushyintas | 18 | 3451 | Mon Apr 14, 2014 2:33 pm by billtr96sn |
Technicalby Gordon SmithTemp sender | 10 | 1808 | Tue Apr 08, 2014 4:34 am by Rick G |
Will dressing welds compromise structural integrity?by robmack | 4 | 1547 | Mon Apr 07, 2014 7:46 am by K75cster |
Trailer balancing.. Can i move the weight further to the rear?[ 1, 2 ] by Rendrag | 57 | 4850 | Fri Mar 28, 2014 5:27 am by Ed |
HELP! vent hose & overflow hoseby emmanuelfiadjoeHELP! how to identify | 2 | 1781 | Thu Mar 20, 2014 5:36 am by Erman |
misfire helpby thumperslaw | 9 | 2063 | Sat Mar 15, 2014 8:03 pm by japuentes |
What to do with my radio?by Mike101 | 10 | 1970 | Mon Mar 10, 2014 1:14 pm by klamityboy |
white pipeby michaellaw | 3 | 1501 | Fri Feb 28, 2014 11:16 pm by RT |
Balancing wheels using a ball/golfballby Corkboy | 4 | 1541 | Mon Feb 10, 2014 6:33 pm by Two Wheels Better |
Fuel level sender fix for aftermarket speedometersby Oliverinlux | 2 | 1580 | Thu Jan 09, 2014 11:47 am by Oliverinlux |
Just connected AM koso speedo to k75, tach not reading correct or is it?by Oliverinlux | 7 | 4438 | Tue Jan 07, 2014 4:13 pm by Oliverinlux |
Errors in Micro Fiches and a refresher on fastener nomenclatureby jjefferiesRealOEM and MAXBMW microfiche errors and query | 5 | 1395 | Wed Dec 04, 2013 10:06 pm by duck |
Fuel pump replacement queryby ianburgess | 11 | 2149 | Mon Nov 25, 2013 7:39 pm by Rick G |
Changing brake hosesby Mike101 | 6 | 2347 | Tue Nov 19, 2013 9:19 pm by duck |
Which range for low torque driver?by robmackWhat Nm range is best for low torque fasteners on K-bike | 6 | 2008 | Wed Nov 06, 2013 10:42 pm by robmack |
RECALCITRANT THERMO FANby Giddyup | 17 | 2249 | Fri Nov 01, 2013 12:10 pm by charlie99 |
Has anyone seen this headlight mounting before?by alanretired '85 K100Headlight mounting | 4 | 1786 | Tue Oct 22, 2013 3:40 pm by the.postman |
Should I be clutchless shifting my k75by Oliverinlux | 5 | 2205 | Sat Oct 19, 2013 10:03 pm by Rick G |
Muffler removalby Rickmeister | 14 | 3138 | Thu Oct 17, 2013 5:09 am by K75cster |
Fuel linesby TomnelWhen need fuel lines be replaced for proper maintenance? | 5 | 2075 | Wed Oct 16, 2013 8:56 pm by Rick G |
Slow-running clock.by AJ.Valente | 6 | 1502 | Wed Oct 16, 2013 12:12 pm by AJ.Valente |
Speedo bluesby Guestspeedometer has stopped working | 14 | 2032 | Tue Oct 15, 2013 8:04 pm by Guest |
Brake pads in Australiaby Matthew-Brisbane | 4 | 1687 | Fri Oct 11, 2013 5:30 am by Matthew-Brisbane |
Pulled the trigger today - shock and springsby HellFishTat | 2 | 1425 | Thu Oct 10, 2013 7:25 am by HellFishTat |
Inside Diameter of Cooling Hosesby Keg | 7 | 1930 | Mon Sep 30, 2013 10:25 pm by japuentes |
was i running out of fuel....by aeronut7k100rt missing at 180miles | 11 | 1678 | Mon Sep 30, 2013 8:56 pm by Rick G |
Wheel helpby thumperslaw | 24 | 2179 | Tue Sep 24, 2013 6:37 pm by thumperslaw |
85 K100rt towbar??by normanmarina | 11 | 2746 | Sun Sep 08, 2013 7:19 am by Ed |
Engine Queryby hopping madK100 ~ Advice needed - Potentiometer | 2 | 1561 | Sat Sep 07, 2013 4:14 pm by hopping mad |
suggestions on removing scratches from system casesby wildwestrider | 1 | 1457 | Mon Sep 02, 2013 9:51 pm by Rick G |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
