Technical, repair and troubleshooting
Forum | Topics | Posts | Last Posts |
Electrical | 2181 | 26936 | restoration of t... Thu Nov 21, 2024 2:01 pm glennpm |
Frame, fairing and wheels | 1692 | 18541 | Lighting upgrade... Today at 10:16 am Tranberg |
Engine and transmission | 2173 | 29876 | Idling problem... Mon Nov 18, 2024 9:54 am glennpm |
How to – Article from you telling others how to do a specific job | 219 | 1891 | The ultimate BMW... Fri Oct 25, 2024 1:45 am David Menzies153 |
Other K bricks (K75, K1100, K1) General discussion. | 263 | 3205 | cooling fan fuse... Mon Nov 18, 2024 5:31 pm tinyspuds |
Special tools and jigs | 75 | 847 | K Bike valve adj... Mon Jul 29, 2024 11:56 am Point-Seven-five |
Everything about adding a chair(sidecar) on a K Bike..... | 137 | 1991 | The ultimate sid... Sun Oct 13, 2024 5:58 pm Dai |
K bikes and trailers | 12 | 162 | Adding a Kamper ... Mon Oct 09, 2023 5:01 am Tranberg |
Topics [0]
Accessories plug? Need help identifyingby Heresy23 | 9 | 1339 | Mon Oct 21, 2019 10:30 am by duck |
Rear swingarm exchangeby Maecky | 15 | 2427 | Wed Oct 16, 2019 2:37 pm by Suzi Q |
K100 odometer repairby DeanG | 8 | 1548 | Sat Oct 12, 2019 9:26 am by Ash |
Injectors not firing / how to test ecu and harnessby futech | 10 | 3375 | Mon Sep 23, 2019 7:46 am by Laitch |
K100 strobe light lamp adjustmentby PiotrK100 | 18 | 1842 | Sat Sep 21, 2019 6:42 pm by PiotrK100 |
Rear Brake - Hard/Spoft Pedalby cyclemanRear Brake - Hard/Spoft Pedal | 1 | 1107 | Mon Sep 16, 2019 11:54 am by 92KK 84WW Olaf |
Clutch Cableby tjh1985 | 5 | 1146 | Mon Sep 09, 2019 5:54 pm by tjh1985 |
Sticky Down Shift...Spline Lubeby tjh1985 | 4 | 1139 | Tue Sep 03, 2019 1:21 pm by duck |
Hesitant starterby davemadsen | 6 | 1225 | Tue Sep 03, 2019 10:39 am by 88 |
In tank hose routing 86 k100by BRogers | 19 | 3812 | Mon Sep 02, 2019 5:51 pm by duck |
No start. K1100ltby Ciaran | 14 | 3076 | Mon Sep 02, 2019 6:22 am by duck |
K1 For Sale Cooroy QLD $11,850by GF Wollongong | 1 | 1014 | Mon Sep 02, 2019 4:43 am by Matthew-Brisbane |
Fuel tank leakby Porto | 5 | 1170 | Tue Aug 27, 2019 5:04 am by Porto |
Temperatue gauge questionsby Ash | 9 | 1369 | Tue Aug 20, 2019 4:33 am by Arlina |
Final driveby smoll1 | 5 | 1420 | Tue Jul 30, 2019 4:39 pm by smoll1 |
AB02.5 ABS ECU repair questionby heyskull | 46 | 3660 | Sun Jul 21, 2019 11:16 am by heyskull |
K1200 gas cap mod on my K100 cafeby MikeisonTV | 8 | 1200 | Sat Jul 20, 2019 5:17 pm by MikeisonTV |
Right side standby Porto | 0 | 1447 | Tue Jul 16, 2019 12:32 am by Porto |
Gas Cap Assemblyby elementalfireTrouble with reassembly | 22 | 5465 | Thu Jun 27, 2019 6:58 am by 92KK 84WW Olaf |
Trip Computerby Motormouse | 5 | 1024 | Sun Jun 23, 2019 7:44 am by GB777 |
Another spline questionby Heresy23 | 7 | 1239 | Thu Jun 13, 2019 10:19 am by Point-Seven-five |
Another spline lube question Thanksby Heresy23 | 9 | 1585 | Sat Jun 08, 2019 11:05 am by caveman |
Gear indicatorby Davep | 7 | 1598 | Tue Jun 04, 2019 11:47 am by sidecar paul |
Naughty K 100 rs 1984 model,by moriartifollow/up | 7 | 1203 | Sat May 25, 2019 1:27 pm by moriarti |
BMW Radio CLARION PU9203A - K1100lt 1992by dakelvinatorAnyway of getting the radio code? | 9 | 3636 | Sun May 12, 2019 10:14 am by dakelvinator |
Rattle - not the monkey nutsby GK100 | 16 | 2035 | Wed May 01, 2019 9:55 am by GK100 |
chain tensioner plugby brickrider2 | 2 | 998 | Thu Apr 18, 2019 1:04 pm by brickrider2 |
Fuel leaking from exhaustby FelowBMW k100RS 1989 restoration | 16 | 3522 | Mon Mar 25, 2019 12:47 pm by 92KK 84WW Olaf |
Naughty K 100 rs 1984 model,by moriartiengine cuts out | 20 | 1452 | Wed Mar 20, 2019 3:16 am by daveyson |
Bad misfireby ajsm18Riding to work this morning my 1985 K100RS developed a really bad misfire | 12 | 1344 | Tue Mar 19, 2019 11:42 am by ajsm18 |
Brake lever angleby BooG | 2 | 1109 | Tue Mar 19, 2019 11:02 am by BooG |
Final Drive and Swing arm are seized.by JDiggamusIn the process of lubing splines and final drive and swing arm are seized shut | 17 | 1504 | Thu Mar 07, 2019 10:43 am by Point-Seven-five |
Front brake noiseby andy442 | 5 | 1181 | Sun Mar 03, 2019 4:34 pm by daveyson |
How to rekey a 22Lt top box.by MartinW | 5 | 1044 | Thu Jan 10, 2019 10:41 pm by MartinW |
Gear switch stuck in 1???by yamarider | 20 | 1491 | Sun Jan 06, 2019 5:50 am by yamarider |
Head Scratchingby GF Wollongong1893 K100RS No Start | 16 | 1402 | Thu Dec 27, 2018 10:07 am by Crazy Frog |
Fueling Issue? Whats your best guess?by BikelordFuel Pump, Pressure regulator, or something else? | 11 | 1433 | Mon Dec 24, 2018 9:22 pm by Laitch |
Rear brake master cylinderby GrahameAlternative for K75 1995 ABS | 7 | 1500 | Mon Dec 24, 2018 1:37 pm by Point-Seven-five |
Any real or amateur locksmiths here?by duck | 18 | 1435 | Fri Dec 21, 2018 8:00 pm by duck |
K100rs 16v won't startby Dympo | 22 | 1390 | Thu Dec 13, 2018 2:00 pm by mike d |
Just bought a non running K75C.by kenrams | 5 | 1181 | Wed Nov 21, 2018 1:22 pm by kenrams |
Pinhole in tank, can it be repaired? HELP!by @kustom_motoPinhole in tank, can it be repaired? HELP! | 5 | 1177 | Tue Nov 13, 2018 6:45 pm by indian036 |
Just A questionby yamaguzzi | 20 | 1340 | Fri Nov 09, 2018 7:46 pm by ERasberg |
changing brake hoses on K1100LT (1996)by brickrider2New Stainless steel lines | 2 | 1342 | Sat Nov 03, 2018 5:57 pm by brickrider2 |
sprag sprague clutch easy fix diy[ 1, 2, 3 ] by texbid | 107 | 13325 | Sat Oct 20, 2018 12:41 pm by Point-Seven-five |
How can I safely weld?by Blackthumb | 12 | 1540 | Wed Oct 03, 2018 9:31 pm by duck |
Cracked manifold!by Blackthumb | 14 | 1303 | Sat Sep 29, 2018 10:42 am by Blackthumb |
How to Compression test with no electricity?by Blackthumb | 6 | 1284 | Fri Sep 28, 2018 9:49 pm by Dai |
Fuel Pump and engine run problemby Snapthor | 4 | 1327 | Thu Sep 27, 2018 4:26 am by Snapthor |
K100 model/year parts compatibilityby Blackthumb | 5 | 1491 | Tue Sep 18, 2018 8:17 pm by Two Wheels Better |
Topics [50]
- No new posts
- New posts
- New posts [ Popular ]
- New posts [ Locked ]
